Jeeeezus, do i need help!!!!!
1 following
OL
One Low Accord
Hello again guys! Not sure if any of you remember that post about me purchasing a new compressor and hooking it up to a relay so it doesn't run with the car off. Well..i hooked this bad boy up right...and it seems like its as slow as my POS viair. The shop that i bought it from uses this compressor and nothing else...they said it will fill a 9 gal. in less than 2 (not from empty of course) mins...and i've seen it...fucker is fast!!
My problem is that it isn't filling as fast as they said. It will stay on for about 5 to 7 mins with even a little of play. I'm not sure who makes this beast, but its huge and very dependable!
I was wondering if anyone could help me out in this matter. This is my entire setup:-(2) 3gal tanks with 2 ports on each tank-this bad ass compressor-3/8" SMC Valves w/ 3/8" lines-4 switches...one per wheel.
Someone told me that i should split the line comming out of the compressor into 2 lines, go to 2 seperate water traps then one line into each tank....? Will this help how fast this bad boy fills???? I NEED HELP!!!!!!!!! Any help on this would be much appreciated!!! thank you thank you!!!
s10
last post by baha +1y
