AZ Bag Job Needed
1 following
AZ Bag Job Needed
TaylorAZ
Whats up? I am in AZ I am just seeing what my options are as far as getting my taco bagged. I have a 2001 Reg cab tacoma and I have all the parts to bag it, just not the time nor the welding skills. My list of parts are below, but here are a few things I want included in the install, Gas tank moved up (hangs below frame) Front wheel wells cut (obviously) A custom bridge, not just two bars connected to my notch, nothing drastic maybe just a zigzag or something. If possible a custom mount in the bed for my tanks and compressors (if not this isn't all that important) Also I have purchased a 4 link, I am not to set on which way to run it, so if It needs to be ran reverse or half and half I am not against it, I just want to make sure it is done right, Send me a PM if interested in helping get another fellow mini trucker draggin.
Here is the list ofstuff I already have:
2 RS-62(single 1/2" ports) Slam bags for frontCups for front2 2600 bags for rear,(single 1/2" ports) Upper mounts and axle mounts8 SMC 1/2" valves2 Viair 450 compressors2 Water separators1 adjustable Pressure switch (supposidly hooking upmore than one compressor to it is not a prob)2 Five gallon 8 port tanksAIM Triangular 4 link10 Switch Plexiglass Switch box (prewired)
THINGS I WILL NEED:Airline and fittings,Shocks and shock relocators. (I can get these before install)
s10
last post by baha +1y
