Alright, my truck is leaking pretty bad into the front floor board. I took the kick panel off, and tried finding where it may be coming from but I don't see anything....I am going to go to the pressure wash today i guess and try that approach also.
I tried to see what the cowl looked like and it looked pretty solid, just the random leaves and all. The doors seal good from what I can tell, it doesn't let water in if sprayed by the hose.....
Where else could this be coming from?
DK
diabolic kustoms
heater core or from a acess panel on the inside of the cowl. It is above the heater box.
granth
sorry, should have said its on the driver side only.
yodaforce
The top of my windsheild sprung a leak the other day during a downpour. It dripped right down into the floor.
DK
diabolic kustoms
it may be from above your fuse block. there is a spot were the cowl seam meets the cab seam. they tend to rust there.
hydroyota
did you cut the inner fender to far
granth
i found it.....the guy didn't seal the glass good at all.
