fuel cell
draggin87yota@hotmail.com's avatar
fuel cell
draggin87yota's avatar
draggin87yota
jus wondering wat the people with fuel cells did as far as their fuel gauge goes,i wanna get a fuel cell but i also use my factory fuel gauge,also if anyone has a fuel cell they are selling cheap let me kno
framescr8pintoy's avatar
framescr8pintoy
i modified a fuel cell that i got and have made it to accept all my stock parts. just have to finish it.
yodaforce's avatar
yodaforce
Most fuel cells (if equiped) with a sender are designed to use with a GM guage or most aftermarket guages. If you want to use your stock guage, you will have to modify the stock sender to use in the cell. I chose to use an autometer guage because the stock guage would never read right with the factory sender bent up to fit the depth of the cell and still have full travel from full to empty. It can be done, it's just tricky.
truck action's avatar
truck action
Got a Donner tank & used the flanges into a custom made stainless tank!Use a AtuoMeter gauge, & Venom fuel pump!
twisted minis's avatar
twisted minis
Get a cell deep enough to use the stock sending unit, and make an adapter, or weld the correct bung on before its had fuel in the tank.
framescr8pintoy
not to jock the thread but ive seen a few people make their cells out of steel instead of aluminum... what do you have to do, or do you have to do anything to coat the insides? the stock tank is steel so why not the cell... besides it being a little bit lighter.
kdcgrohl's avatar
kdcgrohl
cause it wont be pretty. thats really the only good reason i can think of aside from weight, which is not a concern for your application.
yodaforce's avatar
yodaforce
Eastwood makes a coating for new steel tanks. I like a plastic cell with foam. Inexpensive, light, durable, don't have to polish, and in case of severe accident, fuel is not spilled out creating a hazard.
framescr8pintoy
cause it wont be pretty? i would think if i made a steel one to have it powdercoated or just paint it. but ohwell
