HELP WITH 2WD CORNER LIGHT REMOVAL!!
evildime2000@yahoo.com's avatar
lowyota95's avatar
lowyota95
HEY THIS IS A STUPID QUESTION, BUT I TRIED TO REMOVE MY FRONT CORNER LIGHTS ON MY 95 2WD EX CAB TODAY, REMOVED THE TWO SCREWS ON THE SIDE OF THE LIGHT AND FIGURED THEY JUST POPPED IN BUT COULDNT GET EM OUT! I REALLY DONT WONT TO BREAK THEM AT THE MOMENT, ANY HELP? IS THERE MORE SCREWS OR WHAT???
THANKS,
LOWYOAT95
kdcgrohl's avatar
kdcgrohl
they have pop in clips in the grill, they pull out. pull harder.
toyota_king_387
they do pop into the grill try to spray some lube in there so they will come out easier..
DK
diabolic kustoms
use a plastic tool and pry them apart. Use lube of some sort.
lowyota95's avatar
lowyota95
OK THANKS GUYS ILL GIVE IT A WHIRL! LOL DAMN THIG WILL PROBALLY BREAK!....
chinkys10
Look at it this way, if it breaks you've got a reason 2 get 4wd fenders and clears!
hng-10w's avatar
hng-10w
i put a flat blade screwdriver inbetween my light & grille and twisted it, the thing popped right off. theres 2 metal pins there so i doubt ull snap anything
lowyota95's avatar
lowyota95
WELL TYPCLY I WOULD SAY THE SAME THING, BREAK THE LIGHT GET 4X4 STUFF, BUT IM LAYING IT OUT WITH THE 2X SHEET METAL AND LIGHTS... SO THAT DOESNT WORK IN THS CASE.... I DID GET THEM OUT, JUST HAD TO PUT MORE UMPH BEHIND IT.. THANKS GUYS
stll2hi's avatar
stll2hi
You could always shave em.
