Installing caddy's
1 following
Installing caddy's
Kappa9012
Probably a question that has been beat into the ground, but I couldn't find shit on the search. What is the best way to install caddy's into a fullsize. I've got a set of buckets from Grant, and I wanted to know do I just put in the fillers, then cut out the opening for the bucket, slide the bucket flush and weld it?
2 Questions:- Do I just cut the buckets off so they are flush with the bezel or do i just leave the light slighty recessed?- The bezel doesn't fit perfectly around the bezel, So do you guys just fill the gaps with body filler, or just leave em?
