What setup does this truck have? Anyone know?
denraweb
I like how fast his bags inflate, holy shit. Is this just a normal system with an added nitrogen tank? Is that what makes it so fast, or do you need more than just nitrogen? Fast bags? Valves? 3/8" sufficient or 1/2"?
maxxinn
It looks like he is running high psi with some half inch valves.
pstlwppd25
definitely running Nitrogen.....
denraweb
So would I or wouldn't I be able to achieve this with just high PSI and a big tank? I really don't want to have to run nitrogen if I don't have to.
payrion's avatar
payrion
yes, my s10 has 1/2 inch valves and 1/2 inch air line and is that fast, however i run out of air fast.... if you use 1/2" stuff and get an 8-10 gal tank with 4 200 psi compressors, yuoull still run out of air but will have faster recovery time. Or go with an engine driven comoressor and have very little down time.
denraweb
Aight so with 1 compressor or two in the future just would take longer to refill right? And I think i'm gonna do like 2 5 gallons under the bed and a 9 gallon up against the cab in the bed.
payrion's avatar
payrion
if you had that much air space in the tanks and only use 1 compressor for now, 1 will take 15 min plus to fill from 150psi to 200psi and youll be replacing that compressor soon . you want a min of 2 compressors per 5 gal of air if you want to recoup your air in a timely fashion. but please remember if you start with only 1 you will replace it when you go to add more due to over use.
denraweb
Oh yea, I meant to say I'm gonna start with a 5 gallon and then make my way up to the 2 5 gallon and 1 9 gallon. So once I'm done, I should end up with 3 compressors? The more the merrier right? Lol.
DD
d3v1ns d50
If your gonna run that much your gonna need to SERIOUSLY upgrade the alternator and batteries.
denraweb
Oh eff that lol.
I'll just buy a new compressor every 6 months lol...
