NEWBIE NEEDS SOME HELP!!!
9
90mm87
Hey everyone whats up? I have a 1990 mitsubishi mighty max i bought for 400 bucks. Its 2wd 2.4l 4cyl 5sp manual. My question is I want to bag this truck and im pretty squared away at what im goin to do with the rear bag set-up but as far as the front goes i dont know I wouldnt know where to begin on how to install the bags im a do-it-yourself person and im a welder by trade does anybody have any tips or installation advive on how to put bags on the front ????? any and all comments are appreciated .
THANKS, -James-
sallen
You might want to check out minitruckins website and look for the stk trk that Ernie macias built it shows some pretty useful info on how they did the front. Hope that helps. If I see any more build threads I'll let ya know. Peace.
slow50
theres a ton of different ways to do the front check out streetsource.com you can search peoples trucks and see how they did theres. there used to be a ton of build threads on mightyd50 but there gone now. heres my build thread
DD
d3v1ns d50
It depends on how low you want it to go and what wheel and tire size combo you are going with. I used to be able to lay frame with drop spindles and the spring pocket cut out on the top with a 1 1/2" tall bag cup on 18" wheels. With the stock spindles back on, I'm about an inch or two frome being frame in front. I'm gonn try and redo the front this winter to get it back frame with the stock spindles. I actually like the stock spindles better than the drop spindles. I can drive it much lower with the stock spindles on then I could with the drop spindles.
