what offset will tuck
lowblazer
long story short i may be buying a set of martin bro wheels for 800 brand new just wonderin if they will tuck. It is a 9.5 inch wheel with a +25 offset. i measured and it looks like it will tuck but not sure.
Heres a pic of the wheel
brianbgboy's avatar
brianbgboy
like i said before, that will be awfully close, and you will need a very small tire. later, brian
8
89zues
ive got 20" helo 828s with 35mm ofset and 9 wide wrapped in 255/35/20 tires. the front clears the fenders fine if there rolled the back on the other hand i had to flair the bed to the max and roll the fenders, it tucks fine till the tire gets towar the top side wer the body line starts then it rubs. u can either narrow the rear 1 1/4" or graft on amigo quarters. itll be tough though with a 9.5, i would recomend an 8 mabey an 8.5 and save the work in the long run
8
89zues
and by the way them wheels look sick, cant wait to see them mounted.
brianbgboy's avatar
brianbgboy
that is a big difference between a 20 with a 35mm offset and a 22 with a 25 mm offset. those wheels are sick, but they will be hard to tuck even with amigo fenders... later, brian
