IVE GOT AN ISSUE WITH TIRE SIZES. I HAVE A SET OF 20'' HELO 828. THEY HAVE A 45MM OFFSET AND ARE 9'' WIDE. I HAVENT PUT THE ON YET. BUT IM BORROWING A SET OF 20S OF A BUDDIES
FULL SIZE WITH THE SAME SPECS AS THE 828S. I JUST FINISHED BAGGING THE TRUCK ABOUT THREE HOURS AGO. WITH THE SUSPENTION SET UP I DID( Z THE FRAME, NOTCHED UPPERS AND
LOWERS AND MAXED THE CONTROL ARMS OUT WHEN LAYD OUT) MY ISSUE IS THAT WHEN IM LAYING IN DOWN IT LACKS 1/2-3/4 OF AN INCH FROM CLEARING THE FENDERS ON FRONT.
INSTEAD THE TIRES PUSH THE FENDERS OUT A LIL THEN CAMBERS FULLY. THE TIRES ARE 255/35/20. DOES THIS SOUND RIGHT AND JUST MABEY ROLL MY FENDERS OR SHOULD I GO WITH A
NARROWER TIRE. ANY HELP WOULD BE GREAT.
tycox
you should try and roll the fenders that is the easiest way out. but if that dont work then see what narrower tire will fit and not looked stretched out on the nine inch rin. i would say like a 225-35 or 235 but i dont know on that rim width
