302 with stock rearend
paparoach1983@hotmail.com's avatar
paparoach1983's avatar
paparoach1983
I am wanting my 6 lug in the rear again and i currently have a stock 8.8 thats 4 lug with a 5.0L. I was wondering if a stock 2.2 rearend will hold up witha 5.0L if i just regular drive the truck????
I know i would peel the tires every great once in awhile but not like everyday
sincitylocal's avatar
sincitylocal
You might get a couple years out of it.
Don't hope for more than that.
If your axle flanges are large enough, just have them re-drilled for 6 lugs.
At least that way you won't be stuck with the 4:10 Mazda gear.
elbine69's avatar
elbine69
Get a b2600i axle and run the rx7 turbo II differential. Limited slip and should hold up a bit better than the 2.2 axle.
paparoach1983
GOTCHA THANKS GUYS
con$truktive
iv seen many b-series diffs used in 9sec rotaries here in australia
axels were redrilled to suit 4stud but seen a few with standard 6stud aswell
id say it would b fine.............& to be abused aswell haha
neptune's avatar
neptune
yeah ur fine man, its not like if it goes out pull a part is short of the b's they always have them!
paparoach1983
cool so i am going to put mine back under it then cuz i want the eskies and i cant do that if i have 4 lug in the rear haha thanks for the help guys
