myspace
24 following
N
myspace
mazdalowrider
just wanted to start this up. if u have a myspace post up ur url so we all can add each other and stuff. here is mine
korrupt1's avatar
korrupt1
I wanna know how in the HELL that one guy with the flat black maz got thos titans in there without using 4x4 sheetmetal? I got myspace but I always forget the URL.....hardly ever go on it....go on facebook more these days
mazdalowrider
what titan wheels?
3day's avatar
3day
i dont know but the back looks extremely close......its in mazdalowrider's myspace album under a show.
mazda rx2000's avatar
mazda rx2000
Ok here it is
mazdalowrider
quick ?, how hard was it to put the 13b motor in and running. and what all did u have to do?
mazda rx2000
It wasnt all that bad trying to find a good motor as a candidate was a Bitc* It took 3 before i found one that ran, since it was a 93 it was FI and I converted it to carb, I made all the block off plates did that and blocked off the injectors, I used a part of the factory Intake were it goes to the motor and got a Racing Beat Manifold and a side draft weber and bolted it up, then the distributor 93 dont have a distributor it has something else and coil pack, but you can take it out and put a distributor in and i put a manual oil mix pump, the cross member had to be moved, drive shaft,tranny mount, the fire wall had to be beat up a little to fit the slave and the starter, the exhaust manifold was a bit tricky i had to cut it and make it shorter to fit, and some other misalliance stuff but it all worked out good Definitely worth doing and When you do a body drop you can keep a stock hood..
korrupt1's avatar
korrupt1
hmmm...cant add sweet but I asked you Jesse....even though like I said...I am barely ever on there...just noticed both me and my fiance say we single....
anyways
Thats mine
1lowb2200's avatar
1lowb2200
smcustoms
