Locked myself outta my truck
14 following
harris1
Does anyone know a way i can open my truck without callin a locksmiths, they are all charging out the ass just to open my door and i thought maybe someone on here knows a trick. i'm no B&E specialist so i wouldn't know the first thing to do... lol
thanks guys
dzminiz's avatar
dzminiz
Extra Key
Get a slim-jim (tool, NOT the snack)
pop out a window
rufus's avatar
rufus
A stiff metal coat hanger work well too.
plumbous blimp's avatar
plumbous blimp
tip, when you open your door, get a spare key cut and hide it on the truck (behind the license plate, behind the tail light, in a wheel well, behind the rear roll pan etc.)
paparoach1983's avatar
paparoach1983
use a hanger and bend it in a big u shape then push it through the window till it goes under and around it then push up on the trim piece of the lock i have done it to mine a few times. giggle the handle as you push up and it will pop open. lol.i dont have pics to show you my truck now just doesnt have locks.
F
frocashmoney24
anouther thing u can do. if it has a slider window, most of the time a screwdriver will get that open. if not, the rear window on these trucks is only held in with a seal. take some screwdrivers and carefully go around the outside, it will take you 10 min to pull the rear window out, and anouther ten to get it back in. just a thought! i know ive done it to mine before with the truck running!!
paparoach1983
^^^^never thought about that one.
91b2200(cody)'s avatar
91b2200(cody)
slim jim that thing... locked the keys in the yota and shaved door handles
so we slimed it and got the pass side open lol
baggedmazda
if you can get your door trim off or look past it there is a little latch that sticks out about 6in down?? push it and it should open your door right up. if not man the rods are so easy to find in mazdas. even a coat hanger and some time and its easy to get the door handle just gota pop that lock up first
p3arlb2200's avatar
p3arlb2200
Lol well now I hope no mazda theives see this
