WTFH!! Vehicle Curse
d.-.r.-.e.-.w@hotmail.com's avatar
90-b22dawg [andrew]'s avatar
90-b22dawg [andrew]
Must be a curse going on down my way....
1st my co-workers van's water pump went out (and cause hes not vehicle savy decided to go ahead and drive it 30 more miles the rest of the home) blew the head gasket and ended up cracking the manifold...
2nd my work van started slipping so i took and had it flushed and the trans filter changed, which made it worse.... then reverse went out... so we ended up having it rebuilt which cost $1700.... 2nd my boss's wife's bmw 6 series transmission started slipping then stopped pulling completely....
3rd my motor mount broke....
now my clucth is gone, it squeels when i push the clutch in... i had my uncle check to see if the slave was working, slave is a slaving... so i called around and cheapest i could find was $300 (i have the clutch already, came with the truck)..
Post was last edited on Oct 15, 2008 12:48. Edited 1 time.
90-b22dawg [andrew]
oh and to top if off i had to re-do a break job on my work van today where the previous brake job wasn't done properly... rotors weren't turned and bearings weren't greased...
89mazdawg(daniel)'s avatar
89mazdawg(daniel)
dang man, sorry to hear
you should be able to get a compleat clutch kit for 125
90-b22dawg [andrew]
i already have a clutch.... just don't feel like taking the time to install it myself... rather let someone with a lift and proper tools do the job... and the guys im planning on taking the truck to, do good work and ive used them for other work on other vehicles several times and "IF" they mess anything up i know that i can take it back to them and they will fix their f-up (which they've only f-ed up once so far and it wasn't anything major)
