just so i understand...
2manycars@adelphia.net's avatar
shilaeli huggr (burdaddy)
i found a set of 17" trailblazer wheels. pretty cheap.
what years of TB's fit the mazdas?
these are 03's i found.
sonikk71's avatar
sonikk71
From the info I found the bolt pattern on those wheels is 6x5. Mazdas are 6x5.5 so they will not bolt up. you could see if you could get them re-drilled but that all depends if the pad is big enough.
crazymikey's avatar
crazymikey
Yeah,those won't fit. You could change your bolt patten of your hubs,but if you do that,may as well go 5 bolt and open up a whole new world of better wheel choices.
