Is there a trick to bleeding brakes with the shared bleeder?
starion88esir@yahoo.com's avatar
charlesskelter's avatar
charlesskelter
My truck brakes like absolute shit with new pads and rotors. Got underneath to bleed it and was like what the fuck when I first saw the shared bleeder on the driver's rear. Also noticed that the two side lines sit as high as the resavior if not higher on the firewall off the master. Who the hell designed the brakes on these trucks? The resevoir is supposed to be the highest point in the system for ease of bleeding. Anyways, any special tricks? I'm tired of having to pump the brakes to get a (remotely) effective brake.
jc50942
i personally have a vacuum bleeder that is a one man operation...you can probally get one cheap if its not to fancy. The one i got i paid like $140 for...but it does alot of other stuff too.
Cusser's avatar
Cusser
Manually adjust the rear brakes, then re-bleed.
Also, if/when you've replaced the master cylinder, you need to match up the push rod free play into the MC to be correct.
mazdaron's avatar
mazdaron
These trucks were built and designed by little men with little hands. lol
rotten
yeah man, i had the same beef with my red one, it took like a full quart of fluid, and alotta pumpin, but got em bled and they worked fine.
