can you drop a b2600 4x4?
X
xaaronx
just need a simple yes or no. i may be picking one up as a daily driver but i'm curious.
91extcab's avatar
91extcab
you could, but you'd have to do an axle flip, and im not sure about the torsions on the 4wd ones as they are mounted slightly different than the 2wd counterparts. and dropping a 4wd one would most likely screw up pinion angles on the front/rear shafts...
paparoach1983's avatar
paparoach1983
you can turn the 4x4 torsions just like the 2wds i helped a buddy lift his there just about the same.
you would need to do an axle flip for the rear but i think you still may be a little cali style even if you do that.
Yes but its not going to be very low
X
xaaronx
thanks for the input, guys. i'll probably just leave it at the height it is now. should be a good truck for winter. it has 31x10.5" tires
edit: here's a pic. it's hella clean
That is pretty clean man, would make a clean lifted truck
dude that truck is sweet lift it 2 suspension 3 body it would look sick i want it
paparoach1983
HAHA I HAVE A SET OF THOSE RIMS.
V
v8mazda4ever
Damn right that truck is sweet i can not believe how clean it is bro good score
X
xaaronx
it's not QUITE as nice as it comes off. i was very mislead by the pictures also lol.
1. tailgate handle is broken off
2. faded paint on roof
3. dash has cracks
4. someone yanked the stereo box thinger and cut the wires to the stereo?
5. there's button-screws in the grille from having a net over it at one point
6. no exhaust whatsoever after the cat
7. clutch reservoir cap is broken, held together by an old rag and electrical tape HA
8. i saved the best for last: it overheated on the test drive because the idiots didn't have enough coolant in it.
there's probably a bunch of other little things i'm forgetting but cosmetically it looks great and seems to run alright
