ok they come in 16*8 only but what offset would work on my truck 91 b26, would the +20 or +10 offset?
link aint workin for me
ridinlow84
The link doesnt seem to be working for me.
9B
91 b2600i
damn. well its rota grid offroads, an they r 16*8 +10 or +20 offset. idk which will be better etc
sonikk71
How low are you? Are you planning a body drop? If so how much? Do you have 4 wheel or 2 wheel drive sheetmetal? All of these things factor into what wheels will fit. I can tell you this if you are bodydropped or plan on body dropping your maz with an 8 wide rim you need a +45 to +51 offset if you want it tuck cleanly. If you are not body dropped and are running 4wd sheetmetal you can get away with a little more provided you roll the fenders. Either way shy of major suspension modifications these wheels will not tuck properly.
9B
91 b2600i
it sits on bumpstops up front an mono with3" block no bumpstop in rear, they come with a +20 2wd sheetmetal, an no plans for bodydrop. im static fornow but will be bagged down the road
