I HAVE A VERY IMPORTANT ?
9B
91 b2600i
ok i have a 91 b2600i
my carrier bearing is gone. i need another and the mazda dealer said its close to 200 for a new bearings with no shaft. plus install of new bearing. but i was wandering if and which other bseries truck that are ext. cab will work. or will i just have to pay out the rear?
slammedyota91's avatar
slammedyota91
Where did you go to get that price? Shop around man, Replacing is something you can do in your driveway man. Check online for pricing. partstrain.com or parparts.com or something , I have found them much cheaper
dr.carnage14
hey guys i have 87 b2200 and i need to know if leaf spings off a ranger will fit on my mazda if they do wat year and if not is there anything that will cuz where im at there is no mazda around
mazdaman82's avatar
mazdaman82
i thank i got a new one if i can still find it got it and then found i had a 4x4 shaft in my truck, so if i can find it i got one if you want it..20+ shiping
elbine69's avatar
elbine69
If you get one from another truck, it will have to be from another b2600i with the same kind of transmission that you have. The ends are different between the manual and automatic transmissions. A drive shaft from a 2200 will work, but you'll have to change the end of the shaft to work with your trans.
dropped90(justin)'s avatar
dropped90(justin)
whoa marcus is back from the lost pile!!!!!
-justin
sincitylocal's avatar
sincitylocal
If you only need the bearing, and not the whole carrier assy, Autozone has them for $13.
9B
91 b2600i
i need the rubber piece that is on the shaft.
droppedmydawg
You need an ext. cab carrier bearing off of any ext cab Mazda 86-93. They are $132 at Napa or if its just the bearing and the rubber is okay then Autozone offers a bearing for $18. Good luck -Ed
droppedmydawg
Here is one for $45 sent to your door!!
