What valves are you running? Size? Brand?
disturbindelrio@aol.com's avatar
baggd's avatar
baggd
I'm currently with 6- 3/8" SMC and 2- 1/2" SMC running to lift the front. What is the biggest valve size they make and air line? Which valves are the "best" in your opinion?
Thanks for your input.
suicide's avatar
suicide
iam running 4 gc extreme 1/2" valves and line. i really like blitzluft valves though
baggd's avatar
baggd
^^Are they fast?
suicide's avatar
suicide
the gc extremes are very fast. and as for the blitzluft they are the same but they only people who sell blitzluft is FBI which sucks butt and the last i heard blitzluft isnt around anymore.
the gc extreme valves are completely rebuildable and they are reasonablely priced. i have the 250 psi ones and theres also 400 psi ones
90-b22dawg [andrew]'s avatar
90-b22dawg [andrew]
im going to run my smc 3/8s.... ive seen 3/4 valves and 1" air line on some of the pro hoppers
mazdawg(mikey)'s avatar
mazdawg(mikey)
ive got 4 parker 1/2 for the up and 4 smc 3/8 for the down
slammedmazda's avatar
slammedmazda
Im running 8 Asco 1/2 valves and 1/2 line. There pretty fast,but im only running 2 Viair 400's at only 150 psi. Plan on getting 2 480's in the future. What are you guy's running for compressors? And pressure switch's?
mazdawg(mikey)
im running 3/8 line throughout mine. i got 2 viair 380's and a 150 psi switch.
90-b22dawg [andrew]
im running stock ac comp. converted to greese sanden 708. fills 5 gallon tank 0-200psi in right at a min at about 1500-2000 rpms. 160-200psi pressure switch
speedster93b's avatar
speedster93b
i've had my smc 10mm valves working on my truck since 2002 (but its been sitting for the last two years, so...) i've put them thru about 5 years of use. they always worked great, but tend to stick in the frozen winter months. a water trap would prb help that out lol.
