Towing
Towing
mazdadropped
My trucks slammed and will not go up/down and i want to bring it home any ideas on what i should do ? i was thinking i should find a place to jack it up n put blocks ontop of the axle to hold up the frame a bit higher any other tips/ideas?
badchicn (rick)'s avatar
badchicn (rick)
Honda Cars have some low profile jacks you can use to get it off the ground, then for the front you can wedge a 6" chunk of 2x4 between the bag mount and the lower A arm. The rear is slightly harder. Are the bags shot? Do you have access to them through the bed? How about a short line with a schrader valve pushed into the bag connector, then air it up with a shop compressor/portable air tank. If the bags are good you could do it to all four. I have four of these short pieces of line in my tool box for emergencies. If the bags are done, you can put a 4x4 wood block in their place. A lot more work.
mazdadropped
Ye i think the bags are shot and i have my entire bedfloor cut out so its easy to access them but yeah the valves wont work at all they are disconnected and i got no compressors , so iwas thinking of jackin up the rear somewhere o nthe frame or gas tank cuz im swappin in a fuel cell soon and ill put blocks under the frame/inbetween the axle but im unsure how to do the front
90-b22dawg [andrew]'s avatar
90-b22dawg [andrew]
for the front you can put the jack under the lower control arm.... jack it up then put the front on jack stands... then take the bags out and put a 6" piece of 4x4 wood...
