im running 1/2in valves and line and wondering how much psi i should run so i can get a pressure switch. i was thinkin around 120-150.
maztang (ryan)
what are your compressors rated at?
bjv7022
i have dual 380s. it has a pressure switch but i was wondering if i should drop it down so i don't hop ma truck. think its at 2oo psi
dropped90(justin)
what size valves and line you running? i have half inch valves and half inch line on 200 psi and only get the the wheels on the front of my truck about 2 inches off the ground. so valve size and line size matters.
-justin
dropped90(justin)
lol sorry some how i missed that. it will hope the truck. you could do like 120 to 160 and be okay. or you could possibly put a plug in the valves to slow them down.
-justin
maztang (ryan)
this is what i would suggest bro or you could go with a 165/200. you are gonna want 200 for the front, but yeah, you will probably hop the rear. what size bags are on the rear? i have re7s which don't take as much pressure to lift as the re6s so mine hops in the rear at 200 psi. but you could always lift the front first then the rear while the pressure is low. or get a reducer right before the fill valve. hope this helps bro.
mazdawg(mikey)
omg thats alot of 1/2 in stuff. i wouldnt run 200psi. ive got dual 380s and i got a 145 psi switch. i gave that 200psi one away....lol
bjv7022
i will be running re8s in the back. think i will go with the adjustable switch. so do i need two if i have dual compressors. i know it may seem dumb but im trying to fig everything out before i start on it.
mazdawg(mikey)
no you just need one pressure switch and 2 relays.
