leaking brake fluid
leaking brake fluid
choppedmazda
im leaking brake fluid from my brake master cylinder is there anything i can do to stop this or do i have to go buy a new brake master cylinder lemme know asap
saveacivic
i would buy another one. you can rebuild yours but it is almost the same cost for our trucks and save yourself the foul language when working with those little c clips consider that an easy fix
slamsonthedawgmaster's avatar
make sure you bench bleed the new master before you install it (thats what those little plastic hoses and fittings are for..lol)..if you dont bench bleed first it pushes a ton of air thru the system and causes alot of other problems...
