clutch or slave cylinder
F
20b2000
how do i know the difference between the clutch and slave cyl. going out????? it is kinda hard putting the truck in gear . so i thought iwas low in fluid but not. the clutch seems to not engage???? no pressure. it sticksto the floor..... thanks for the help guys....
mazdatweaker
post deleted
Post was last edited on May 13, 2009 12:31. Edited 1 time.
20b2000
thanks man ill check in the light tomorrow. is that port checkable???? and any idea on prices for slave?
mazdalowandslow's avatar
mazdalowandslow
slave should cost around 20 and master about 30
20b2000
thanks .
slamsonthedawgmaster's avatar
you should repalce them both at the same time no matter which one is shot..i've had a few problems with doing a master or a slave then having the new part cause the demise of the old part..it's just cheap insurance to make sure you don't get stuck on the side of the road!
