i was looking for a thread on it but can't seem to find it.
i have an idea but i don't want to mess up ma paint. how should i do it.
cut it with and air wheel? try to bent it up?
plumbous blimp
bump, i need clearance on 2x4 fenders
lvnlo
to roll mine, i just grabbed my trust baseball bat and rolled itover the wheel on an angle, takes a bit of working to get it even but does the trick
droppedmydawg
I used a block of wood on the outside while lightly tapping with my itty bitty baby hammer. I worked it up a little all the way around where I needed clearance. I then went back over it all again and again until I had the desired flat lip. You are going to damage your paint. If you flex the paint on an edge like that it is going to want to maintain its original dried position. I would never cut it, because you lose all the strength of the metal there. Good luck -Ed
bjv7022
damn.
guess i will have to come up with something else
ricksb2200
haha i used a mallet with a rubber head and my leg worked great but if you need some more information try this link
