another problem
carrot_top12_88@hotmail.com's avatar
another problem
red_b2200's avatar
red_b2200
i got my engine driven tapped out everything works i left the intake ac line on the back of it. my truck wil stay lifted for about 5 minutes then it starts leaking out air slowly out the intake port of the compressor. i took the back of the compressor off to drill and tap it out. i made sure it was tight what could be my problem maybe its not perefectly ligned up or something any help. thanks
run a check valve in line to prevent air leaking back into comp
jester's avatar
jester
^^X2
red_b2200's avatar
red_b2200
ok i ran a check valve and its still leaking down. what could be causing it im getting pissed.
get a spray bottle put in 5 or 6 drops of dish soap and start spraying man...spray every connection..and go from there if you see bubbles you found your leak
red_b2200's avatar
red_b2200
did that everything is tight. i got my check valve at lowes think nmaybe its not air tight. it slowed it down a whole lot but it still leaks slowly.
_
_juice_
if you sprayed soapy water on every fitting and saw no bubbles anywhere then your check valve might be bad, you need to buy a good SMC one and not a shitty homedepot one. if it still leaks after getting new check valve...... i guess just deal with it, nothing else could be leaking....
red_b2200's avatar
red_b2200
thanks a lot guys this is my first mazda build so ill have pleaty of questions.
