switchbox wiring
U
switchbox wiring
phatmike
im after a wiring diagram for a avs arc-9-bk
seem to have lost my diagram when i moved house.have tried emailing avs but no luck
if anyone can help please reply or pm
thanks mike
check suicied doors web site i think they have it there
trplezro's avatar
trplezro
Did you email Kris directly?
They're at SEMA right now from what I hear so it may be monday before you hear back.
If not email She's quick to help
Suicide Doors has wiring for the older boxes and the nonterminal strip ones.
phatmike
thanks for your help,i origionally messaged them thru their website.have now emailed kris directly will hopefully yeld some results
h2omelon(nick)'s avatar
h2omelon(nick)
The box is labeled for each terminal and is really simple.If you need help pm me and I'll give you my number and try and help you over the phone.
phatmike
unfortunatly this one hasnt got any labels
devb22's avatar
devb22
If you wire it normal, with the wire out the top of the it should look like this:
If you did it upside down, with the wire out the bottom it should look like this:
The terminal connections should hook up as follows:
12. driver front up
11. driver front down
10. passenger front up
09. passenger front down
08. driver rear up
07. driver rear down
06. passener rear up
05. passenger rear down
04. remote up input ( optional )
03. remote down input ( optional )
02. ground
01. +12 volt input
Or you can use the colors if they are supplied:
pink=+input
white=front left up
yellow=front left down
orange=front right up
red=front right down
grey=remote dump
green=rear left up
blue=rear left down
purple=rear right up
brown=rear right down
Hope this helps man....
Dev @ The Bag Shack..
phatmike
thanks dev,will try that out once i get the truck back
