Import a 4x4 LSD???
ryan@ryanandfawn.com's avatar
Import a 4x4 LSD???
ryan_b2k's avatar
ryan_b2k
With all the talk about pulling LSD's out of rx7's and what not, you run into real hangups with 4x4. besides losing your 4.44 ratio, you have to find a diff to fit the front as well.
here's my idea:
Why not import the Diff's from an Aussie truck? They had LSD there as a common option and I'm sure there are good ratios. has anybody done this?
Aussie truckers: What ratios could you get with the LSD and is it rear only or front and rear LSD?
ryan_b2k's avatar
ryan_b2k
anyone?
elbine69's avatar
elbine69
Cuz getting one from australia would probably be pretty expensive
dvsdev
Really expensive.
have you tried Ford?
I have a courier which is the same as aB2k and it has a lsd from the factory, I don't know if the US ford is the same as the ours but it could be worth a try.
Even brand new from a dealer would probably cost less than getting one from here or Oz up to you.
ryan_b2k's avatar
ryan_b2k
ford is a great idea, I never thought of that.
