brake question.
dropanddrag@hotmail.com's avatar
brake question.
josh's avatar
josh
well ive swaped the spindles to 01+ silverado spindles and hubs. i was wondering what big brake kit i should go with or will stock work fine on my little truck? i have a pretty powerfull 350sb going in it. i was looking at the willwood big kits but they are 2300 bux.
josh
cid (dale)'s avatar
cid (dale)
Honestly if your swapping a 350sb in that little thing I would recommend spending the big bucks on stopping power. Not only will it drive and brake better but it'll help you stay alive when your needing to stop really fast. I'll have a look and see what I can find that's a bit cheaper but I think everyone on here will say get a good brake kit for her .
Dale
josh's avatar
josh
ya, i like living. plus i think a big brake kit will look bad ass behinde the 4's. hell ill be tucking brake rotor and caliper! im thinking i might go for a ssbc kit. just gotta see what the prices are.
josh
90-b22dawg [andrew]'s avatar
90-b22dawg [andrew]
i see willwood kits on every damn thing at shows.... what about brembo
speedster93b's avatar
speedster93b
yeah no shit u gotta upgrade that brake stuff.
as far as companies, there's also baer other than those already mentioned.
also badchicn got a brake kit from phatties.. don't know anything about them but thats another name to check into.
i prefer wilwood tho if you want my opinion. they are a local company and i've installed several brake kits ranging from the basic dynalite caliper on an 11" rotor (we make custom brackets for the mustang rotor) to 6 piston calipers on 13 inch rotors and they're all fairly simple to install. i've got a set of 4 piston calipers on mine. you'll need to upgrade your master cylinder to a bigger bore size tho. if you call wilwood they sell a master cyl that i'm sure will accomodate you. their number is 805-388-1188
speedster93b
i usually see stock
91b2200(cody)'s avatar
91b2200(cody)
JOSH : PM'ed YOU ..... about if ya got emblems yet that i sent you
