Will these tuck?
E
Will these tuck?
hex0rz
4x4 fenders in front, and no mods in the rear.
I want to know if an 18x8.5 rim with a +15mm offset and 225/45 tires would tuck?
ask dev...lol
RX
racer x
I doubt it.
devb22's avatar
devb22
Lol!
Well the front will be fine, as long as your not running drop spindles....I think you'd still be okay either way!
As for the rear, its a big NO!!! Especially with stock 2wd sheet metal you are very limited....
Hope that helps!
Dev <img src="{SMILIES_PATH}/icon_biggrin.gif" alt=":D" title="Very Happy" />
hex0rz
...ahh crap! How much would it stick out by? Any way I could remedy this? 4wd sheetmetal would'nt even work? WOW! lol...
madmazda
It has been pretty well established that if you have a wheel that is between 7-8 inches wide, you'll need that wheel to have somewhere between +38 and +44 milimeters to be able to tuck. Keep in mind that tires may play into your equation, too. A wider tire may have a more difficult problem tucking than a more narrow one.
devb22's avatar
devb22
There is always a way to make it work! It's just metal!
You can flare the bedsides out a bit, which works well if you do it right! There is an article in MT about this, and they do it on a Mazda too!
You can get a pre-84 Mazda axle that will be a little bit narrower, which will give you a bit of clearance...
Or just keep searching for the wheel that works...Lol!
Dev
dropped90(justin)'s avatar
dropped90(justin)
i posted that bed flaring link in the how-to category a few months ago.
-justin
hex0rz
Yea, I remember seeing the bedside flare trick on a site before... Dunno, might do it, just not sure about how it would look flared...
The rims I want are so badass! I really wanna fit them on my truck! Would the pre 84 axle just bolt right up to my driveshaft?
I need to get on the truck soon and take some measurements and see what the numbers will say...
I mean, shoot, how much would these things stick out by? They can't stick out THAT much?!
noridetoolow's avatar
noridetoolow
to go pre 84 will require having a shop cut the yoke off of your driveshaft and welding on the yoke from the pre 84 driveshaft. This is exactly how my truck is setup, 74 Courior rear end, I have the couriors driveshaft yoke welded to my Mazda driveshaft. It cost me $60 to have this done.....i didnt think this was bad at all. The only other issue is that depending on how old ( and perhaps all pre 84 are like this?? ) the rear brakes parts are a pain and EXPENSIVE to peice together....dont know about all years but mine has 2 wheel cylinders per drum, $35 each....plus more junk and on an older axle like this, you very well may end up having to replace most of the brake parts. Please yall, correct me if I am wrong, I am basing all of this on the 74 axle on my truck.
