so...this is my first bagged Mazda...are they all prone to the drivers side lean? Does anything help? Other than 4 valves for the front?
macdave06
if you're splitting a line for the front its gona do that cause you got more weight on one side. even mine when I just lift the front it lifts the passengers side more, and I have an 8 valve setup.
noridetoolow
2 valves....running from the back via one line....split in the engine bay......
90-b22dawg [andrew]
with 1 line its going to lift to the lighter side when your tring to lift both sides up at the same time because its less force to lift the lighter side and the line is depressurizing at the same time for the 2 bags.... 2 seperate lines from the tank to the front should take care of that problem because you have more volume of air flowing and the pressure should be equal.... don't take my word for it though im just putting my 2 cent into this.... i've never owed a bagged vehicle but have helped plumb a few
