Please Help
bigworm40965@yahoo.com's avatar
Please Help
dropndragmazda's avatar
dropndragmazda
Alright i have a problem , my rear passenger side wheel is wobbling @ 40-higher mph like it is bent! I had it rebalanced and the wheel is straight and it is still doing it, keep in mind i have a full leaf spring pack wit 3 in blocks but NO SHOCKS. Just the passengers side rear is doing it..any ideals???
dropndragmazda
wheel bearings??? BUMP
dropndragmazda
dayyyyum no 1?
bodied b2600zx (josh)
doesnt really sound like a wheel bearing, driveshaft maybe???
noridetoolow's avatar
noridetoolow
any chance the axle could be bent? I know mine is...I dont feel it but you can see it wabble even when turning it by hand. I am about to drop another axle in it. My pass side had been hit pretty hard on the bed side prior to my buying the truck so I am not suprised
noridetoolow
ya know....I was just thinking....pass side is your primary wheel that moves the truck....limited slip differential...pass side wheel moves when you hit the gas...drivers side only moves when the pass side is not getting any traction....so with this is mind, you might have some drivetrain issues that are being transfered to the pass side wheel.
dropndragmazda
i don't know , i am freakn puzzled!
i did drive it back 60 miles wit the drive line in a slight bind, when pickn it up from the fabrication shop...
noridetoolow
i dont know either.....i know you had the wheel balanced....maybe just for the heck of it, swap back wheels and make sure the shimmy is still there??
the u joint maybe?? I dunno if thatd make it shake that bad or not
elbine69's avatar
elbine69
Yah try switching wheels and see what happens.
