Will they fit?
Will they fit?
dvsdev
I'm looking at fitting Mazda Proceed doors to my 94 Ford/Mazda B2200 Ute so I can have electric windows.
I saw them yesterday when I was getting the bonnet for my Ute and they look the same size, does anyone know if they will fit and bolt straight up?
Obviously I would need to run a whole lot of wires between them for it to work but that doesn't phase me.
devb22's avatar
devb22
I have no idea what a Mazda Proceed is...
Dev
slammed83mazda's avatar
slammed83mazda
protege' ?
elbine69's avatar
elbine69
I read that Mazda called some of the there trucks Proceed's in other parts of the world. If thats the case then the doors should be the same. I dont really know for sure though.
dvsdev
Oh yeah I forgot that we have different names for stuff here, sorry.
Basically it looks like a b2000 4x4 SUV.
The bonnet has the lump in the middle and the front guards are flared more, these parts are commonly taken and put onto the utes here when people bag them for clearance issues I believe.
elbine69's avatar
elbine69
Oh I see. Sounds like it has the hood like the b2600i does and the 4x4 fenders like our trucks have. There probably the same doors then.
devb22's avatar
devb22
Good call!
Dev
dvsdev
Thanks guys, I thought i'd ask just in case someone had them fitted already.
I'll get them and all going well they will fit and then it's just some wiring that i'll have to make and i'll have electric windows.
jester's avatar
jester
The mazda b-series pickups have quite a few names in other countries, Proceed, Bounty, Marvie, and Courier too name a few
noridetoolow's avatar
noridetoolow
Follow the wiring from the doors as far into the cab as you can, get everything it plugs into and cut as LITTLE as possible. worse case scenario...if the wiring is solid all the way into the cab ( like a Honda Accord I swapped doors on once ( all FOUR )) then you will have to cut the entire harness and resolder every wire....BUT....so long as you keep all the under dash crap from the donor truck\SUV that the wires run to, then you should save yourself some wiring nightmares trying to figure out what wire should do what. g\l
