master cylinder discussion
southernrazed
i saw this discussed a while back and i saw twisted posed about using a manual chevy master cyl. my question is will it give me enough umph to run my front and rear disk brakes.. what is the pedal feel like with manual brakes i have no idea..thanks in advance.
southernrazed
well i just did a little research and found altough its not the best idea i can be done.. i really have NO room for a booster either under the dash or on the firewall so i was thinkin i could run two manual masters linked paralell one for the front and one for the back..
southernrazed
scratch that...no room either...will one suffice?
twisted minis's avatar
twisted minis
If you have 4 wheel discs, I would call up Wilwood and tell them you need a manual master cylinder for 4 wheel discs. They will set you up with the right stuff, and their manual masters are about $75 alone. They double if you want one with a pedal assembly.
Anything you buy at the store will be for drum/drum or disc/drum. They didn't really run manual brakes a 4 wheel disc cars, but Wilwood makes it possible, and safe.
It will stop fine, but you will have a stiff pedal. At first it will feel STIFF, then your leg will get used to it and be no problem. I daily drove a manual 67 Mustang for a while, once you get used to it its easy. But when you get into something with power you stop short for a few miles.
Also, look into Hydroboost. Its a lot more money, but works just as well as a boosted system, but takes up the space of a manual system.
southernrazed
sweet man yea wiilwwod why diddn't i think of that. good call...im a get out the summit catalog now thanks for the help..
twisted minis
I would actually call Wilwood, or an authorized Wilwood specialist about it. Tell them 4 wheel discs, on about a 3000 LB vehicle, length of your pedal, number of pistons on the calipers, etc. Then they will match you with the right one. I would ask for that PN, and then order that from Summit if their prices are better than the specialist, or Willwood direct.
southernrazed
yea i will man... im gonna go with one of their dual pedal assembly's matched with whatever masters they recommend i need .... so sick..
