FRONT BRAKES SEIZE IN REVERSE
spencer.allen@nf.sympatico.ca's avatar
seethru's avatar
seethru
Unlock again in foward,
this only happens when it's below freezing. Any ideas???
hocbj23
u sure it is the front?When u back up and apply the brakes Maz has a self-adjuster that tightens the rear drum brakes.To my knowledge no way to adjust the front discs.R ur pads and rotors ok?BJ
seethru's avatar
seethru
front brakes fer sure
hocbj23
Only thing I can think of would be that in very cold temps the brake fluid would flow slower and when u applied the brakes for the first time in the am the pads would contact the rotors and bind for a moment until the fluid pressure dropped and released them.Might want to completely drain your brake fluid,replace with fresh fluid and bleed your brakes.Dirty fluid wont help.BJ
