help wiring in LED 3rd brake light
nascar_rob@hotmail.com's avatar
crash's avatar
crash
hey guys.. last wrecker run that i did I grabbed a roof mounted LED 3rd brake light off an astro van to mount in the back window of my cap ... it's a two wire deal ...
I'm wondering what two wires that I tap into in the mazda tail light harness to get this thing working
thanks
one is a ground...just pull a tail light and probe the wires with someone pumping the breaks when you find the the that blinks with the pumping of the break pedel your set
hocbj23
There should be a brake lite switch located on or near your brake pedal in ur cab.Wire it to that-will be closer than the rear brake lites.BJ
fanninator's avatar
fanninator
nah hoc, hes mountin it on the window of his topper. -bf
crash's avatar
crash
correct... mounting it in the cap.. not the cab. and i tried the wires thing... i'm going to post on the astro site also... maybe there's supposed to be some weird resistor or relay in-line the i don't know about..
hocbj23
Sorry-I thought u were going for the back of the cab.My boo-boo.BJ
hocbj23
Bump.I seem to recall on one of my Maz trying to wire up trailer lites from the taillite harness and I had to buy a special harness just for Maz.May be the same issue for u.BJ
