need to know bout airbags
kaycee3991
what should i be looking for when i buy them like what are they called and are they hard to install ??????????????
devb22's avatar
devb22
OH BOY!!!
Just do your research here on the site and others as well...There are 4 major manufacturers of bags imo. Airlift, Contitech, Firestone, Slam Specialties
They all come in different sizes/model numbers/series. Here is what you can expect to see:
Slam Specialties (the best bag imo) for example has 3 different series of bags. RE/HE/XS all of them have the same basic sizes.
RE-5, RE-6, RE-7, RE-8
HE-6, HE-7, HE-8
XS-6, XS-7
The RE Series are rated at 200psi, HE Series at 400psi, XS Series 600psi
The number next to the model number refers to the Max Diameter @ 100psi in inches. So the RE-5 is 5 inches in diameter, RE-6 would be 6 inches and so on. The RE-8 and HE-8 are 7.75" in diameter.
Contitech has a similar approach as follows:
2500 which is 6.5" in diameter
2600 which is 7.7" in diameter
All rated @ 120psi
Firestone is also fairly similar to Contitech as follows:
25 which is 6.4"
255/2500 which is 6.4"
224/2600 which is 8"
26/2800 which is 8.6"
All rated @ 100psi
The psi rating is the Maximum Recommended Pressure, they are know to exceed those numbers and work fine... Maximum diameter of Firestone shown is at their maximum recommended pressure. However as pressure increases, so does the diameter. Slam Specialties sizes remain constant at any pressure.
Hope this helps!
Dev
87mazdamini's avatar
87mazdamini
You don't want air bags too much of a pain to install and not worth your time. Just leave your truck stock and sell it to the next old man you see with a motorhome.
devb22's avatar
devb22
Good Call!
Dev
87mazdamini
God who knows I'll probably get nasty messages for that too huh! ha ha!
87mazdamini
No but seriously I personaly like the Slam Specialty bags. Tough as nails and depending on how much psi you plan on running they have a variety of psi ranges just like Dev just mentioned.
devb22's avatar
devb22
So, I guess this wasn't very helpful?
Did you get a nasty pm 87?
Dev
kirk's avatar
kirk
Thanks for that helpful info Dev.
nytrdr24's avatar
nytrdr24
that says it all.... excellent info dev, I didn't even know that!
87mazdamini
Nope didn't get any nasty nothing. I was sure trying my hardest though! lol
