mounting bags to lower bars
slow50
i was gona use a bag plate on the lower bar. but with the upper bag plates im using it puts the bolt holes inline with the lower bar. so im thinking i gota drill a hole in the bar and run a bolt inside it. but the lower hole will have to be 3/4" to fit a washer and socket through it. will that weaken the bar? im running a 2x2 1/4"wall bar. i was also thinking maybe weld a 3/4" washer to strengthen the hole?
slow50
heres what im working with
nissandoordragger's avatar
nissandoordragger
youll be fine or depending on the type of bag (slam or dominator) you can use the 2 outer holes and not have to drill threw the lower bar
slow50
ya i got slams but if you look at the upper plate it puts the two lower holes inline with the lower bar. im just gona drill a hole.
msturg's avatar
msturg
I drilled all the way through, welded in a sleeve and just ran a longer bolt, the sleeve will give you back the strength.  With that being said, this is on a light vehicle, not a full size
Marcos_65's avatar
Marcos_65
You'll be fine, thats how the bag is mounted on my KP 6 link
N
NaviGangsta
you will be fine. that upper bracket might be borderline on not having enough bracing though #AdContainer,#RadAd_Skyscraper,#ad-frame,#bbccom_leaderboard,#bbccom_mpu,#center_banner,#footer_adcode,#hbBHeaderSpon,#header_adcode,#hiddenHeaderSpon,#navbar_adcode,#pagelet_adbox,#rightAds,#rightcolumn_adcode,#top-advertising,#topMPU,#tracker_advertorial,.ad-now,.adbox,.adspot,.dfpad,.prWrap,.sponsored,[id^="ad_block"],[id^="adbrite"],[id^="dclkAds"],[id^="konaLayer"],[id^="ew"][id$="_bannerDiv"],a.kLink span[id^="preLoadWrap"][class="preLoadWrap"],A[href^="http://adserver.adpredictive.com"],A[href^="http://ad."][href*=".doubleclick.net/"],div[class^="dms_ad_IDS"],DIV[id="adxLeaderboard"],DIV[id="rm_container"],div[id^="sponsorads"],div[id^="y5_direct"],DIV[id="FFN_Banner_Holder"],DIV[id="FFN_imBox_Container"],DIV[id="p360-format-box"],div[id="tooltipbox"][class^="itxt"],div[id^="adKontekst_"],div[id^="google_ads_div"],div[id^="kona_"][id$="_wrapper"],div[class="wnDVUtilityBlock"],div[style*="url(http://adsearch.adkontekst.pl/"],embed[flashvars*="AdID"],embed[id="Advertisement"][name="Advertisement"],iframe[class="chitikaAdBlock"],iframe[id^="dapIfM"],iframe[name^="AdBrite"],iframe[name^="google_ads_"],iframe[src*="clicksor.com"],img[src*="clicksor.com"],IMG[src^="http://cdn.adnxs.com"],ispan#ab_pointer,object[id="flashad"],object[id="ve_threesixty_swf"][name="ve_threesixty_swf"],[src*="sixsigmatraffic.com"],div#dir_ads_site,div#tads table[align="center"][width="100%"],div#rhs div#rhs_block table#mbEnd,#A9AdsMiddleBoxTop,#A9AdsOutOfStockWidgetTop,#A9AdsServicesWidgetTop,#AD_CONTROL_22,#ADsmallWrapper,#Ad1,#Ad2,#Ad3Left,#Ad3Right,#AdBanner_F1,#AdBar1,#AdContainerTop,#AdHeader,#AdMiddle,#AdRectangle,#AdSenseDiv,#AdShowcase_F1,#AdSky23,#AdSkyscraper,#AdSponsor_SF,#AdTargetControl1_iframe,#AdText,#Ad_Block,#Ad_Center1,#Ad_Top,#Adbanner,#Adrectangle,#AdsContent,#AdsWrap,#AdvertMPU23b,#AdvertiseFrame,#Advertisement,#Advertorial,#BannerAdvert,#BigBoxAd,#CompanyDetailsNarrowGoogleAdsPresentationControl,#CompanyDetailsWideGoogleAdsPresentationControl,#ContentAd,#ContentAd1,#ContentAd2,#ContentAdPlaceHolder1,#ContentAdPlaceHolder2,#FooterAd,#FooterAdContainer,#GoogleAdsense,#HEADERAD,#HOME_TOP_RIGHT_BOXAD,#HeaderAdsBlock,#HeaderAdsBlockFront,#HeaderBannerAdSpacer,#HeaderTextAd,#HeroAd,#HomeAd1,#HouseAd,#Journal_Ad_125,#Journal_Ad_300,#LeftAd,#LeftAdF1,#LeftAdF2,#PREFOOTER_LEFT_BOXAD,#PREFOOTER_RIGHT_BOXAD,#PageLeaderAd,#RightAd,#RightSponsoredAd,#SectionAd300-250,#SidebarAdContainer,#SkyAd,#SponsoredAd,#TOP_ADROW,#TOP_RIGHT_BOXAD,#TopAdPos,#VM-MPU-adspace,#VM-footer-adspace,#VM-header-adspace,#VM-header-adwrap,#XEadLeaderboard,#XEadSkyscraper,#_ads,#ad-120x600-sidebar,#ad-160x600,#ad-160x600-sidebar,#ad-250x300,#ad-300,#ad-300x250,#ad-300x250-sidebar,#ad-300x250Div,#ad-728,#ad-article,#ad-banner,#ad-bottom,#ad-bottom-wrapper,#ad-colB-1,#ad-column,#ad-container,#ad-footer,#ad-footprint-160x600,#ad-front-footer,#ad-front-sponsoredlinks,#ad-halfpage,#ad-label,#ad-leaderboard,#ad-leaderboard-bottom,#ad-leaderboard-spot,#ad-leaderboard-top,#ad-left,#ad-lrec,#ad-medium-rectangle,#ad-middlethree,#ad-middletwo,#ad-module,#ad-mpu,#ad-mpu1-spot,#ad-mpu2-spot,#ad-placard,#ad-rectangle,#ad-righttop,#ad-side-text,#ad-skyscraper,#ad-slug-wrapper,#ad-space,#ad-splash,#ad-target,#ad-target-Leaderbord,#ad-teaser,#ad-top,#ad-top-text-low,#ad-tower,#ad-trailerboard-spot,#ad-typ1,#ad-wrap,#ad-wrap-right,#ad-wrapper1,#ad-yahoo-simple,#ad1,#ad125BL,#ad125BR,#ad125TL,#ad125TR,#ad125x125,#ad160x600,#ad160x600right,#ad1Sp,#ad2,#ad2Sp,#ad3,#ad300,#ad300-250,#ad300X250,#ad300_x_250,#ad300x150,#ad300x250,#ad300x250Module,#ad300x60,#ad336,#ad336x280,#ad375x85,#ad468,#ad526x250,#ad600,#ad7,#ad728,#ad728Wrapper,#ad728x90,#adB,#adBadges,#adBanner,#adBanner120x600,#adBannerTable,#adBannerTop,#adBar,#adBlock125,#adBlocks,#adBox,#adContainer,#adDiv,#adFps,#adFtofrs,#adGallery,#adGroup1,#adHeader,#adL,#adLB,#adMPU,#adMiddle0Frontpage,#adMiniPremiere,#adP,#adPlaceHolderRight,#adRight,#adSenseModule,#adServer_marginal,#adSidebar,#adSidebarSq,#adSky,#adSkyscraper,#adSlider,#adSpace3,#adSpace300_ifrMain,#adSpace4,#adSpace5,#adSpace6,#adSpace7,#adSpace_footer,#adSpace_top,#adSpecial,#adSpot-Leader,#adSpot-banner,#adSpot-mrec1,#adSpot-sponsoredlinks,#adSpot-textbox1,#adSpot-widestrip,#adSpotAdvertorial,#adSpotIsland,#adSpotSponsoredLinks,#adSquare,#adStaticA,#adStrip,#adSuperPremiere,#adTableCell,#adTag1,#adTag2,#adTop,#adTopboxright,#adUnit,#adWrapper,#adZoneTop,#ad_160x160,#ad_160x600,#ad_190x90,#ad_300,#ad_300_250,#ad_300x250,#ad_468_60,#ad_5,#ad_728_foot,#ad_728x90,#ad_A,#ad_B,#ad_Banner,#ad_C,#ad_C2,#ad_D,#ad_E,#ad_F,#ad_G,#ad_H,#ad_I,#ad_J,#ad_K,#ad_L,#ad_M,#ad_N,#ad_O,#ad_P,#ad_YieldManager-300x250,#ad_anchor,#ad_banner,#ad_banner_top,#ad_bar,#ad_block_1,#ad_block_2,#ad_bottom,#ad_box_colspan,#ad_branding,#ad_bs_area,#ad_center_monster,#ad_container,#ad_content_wrap,#ad_feature,#ad_footer,#ad_haha_1,#ad_haha_4,#ad_halfpage,#ad_head,#ad_header,#ad_horseshoe_left,#ad_horseshoe_right,#ad_horseshoe_spacer,#ad_horseshoe_top,#ad_hotpots,#ad_island,#ad_label,#ad_layer2,#ad_leader,#ad_leaderBoard,#ad_leaderboard,#ad_lwr_square,#ad_medium_rectangle,#ad_medium_rectangular,#ad_middle,#ad_mpu,#ad_play_300,#ad_rect,#ad_rect_body,#ad_rect_bottom,#ad_rectangle,#ad_related_links_div,#ad_related_links_div_program,#ad_report_leaderboard,#ad_report_rectangle,#ad_right,#ad_right_main,#ad_ros_tower,#ad_rr_1,#ad_sidebar1,#ad_sidebar2,#ad_sidebar3,#ad_skyscraper,#ad_slot_livesky,#ad_space,#ad_square,#ad_ss,#ad_term_bottom_place,#ad_top,#ad_top_holder,#ad_tp_banner_1,#ad_tp_banner_2,#ad_vertical,#ad_wrapper,#adbanner,#adbnr,#adbottom,#adbox,#adbox2,#adclear,#adcode1,#adcode2,#adcode3,#adcode4,#adcolumnwrapper,#adcontainer,#adcontainsm,#adcontrolPushSite,#addiv-bottom,#addiv-top,#adframe:not(frameset),#adhead,#adhead_g,#adheader,#adiframe1_iframe,#adiframe2_iframe,#adiframe3_iframe,#adimg,#adlabel,#adlabelFooter,#adleaderboard,#adlinks,#adlinkws,#admid,#admiddle3center,#admiddle3left,#adposition,#adposition-C,#adposition-FPMM,#adposition2,#adposition3,#adposition4,#adrectanglea,#adrectangleb,#adright,#adright2,#ads,#ads-468,#ads-area,#ads-block,#ads-bot,#ads-bottom,#ads-dell,#ads-horizontal,#ads-indextext,#ads-leaderboard1,#ads-lrec,#ads-prices,#ads-rhs,#ads-top,#ads2,#ads300,#ads336x280,#ads7,#ads790,#adsDisplay,#adsID,#ads_160,#ads_300,#ads_728,#ads_belowforumlist,#ads_belownav,#ads_bottom_outer,#ads_catDiv,#ads_footer,#ads_right,#ads_sidebar_roadblock,#ads_top,#adsbottom,#adsense,#adsense-text,#adsenseWrap,#adsense_placeholder_2,#adsensetopplay,#adskyscraper,#adslot,#adsonar,#adspace,#adspace-300x250,#adspace300x250,#adspaceBox,#adspaceBox300,#adspace_header,#adspot-a,#adsright,#adstop,#adt,#adtech_takeover,#adtop,#adv-masthead,#adv_google_300,#adv_google_728,#adv_top_banner_wrapper,#adv_wide_banner,#adver1,#adver2,#adver3,#adver4,#advert,#advert-1,#advert-boomer,#advert-display,#advert-header,#advert-leaderboard,#advert-top,#advert1,#advertBanner,#advert_250x250,#advert_box,#advert_leaderboard,#advert_lrec_format,#advert_mpu,#advertbox,#advertbox2,#advertbox3,#advertbox4,#adverthome,#advertise,#advertise-now,#advertise1,#advertisement,#advertisement160x600,#advertisement728x90,#advertisementLigatus,#advertisementPrio2,#advertiserLinks,#advertising,#advertising-skyscraper,#advertorial,#adwhitepaperwidget,#adwin_rec,#adwith,#adwords-4-container,#adwrapper,#adxtop,#adzerk,#adzoneBANNER,#agi-ad300x250,#agi-ad300x250overlay,#agi-sponsored,#anchorAd,#annoying_ad,#ap_adframe,#araHealthSponsorAd,#article-ad-container,#article-box-ad,#articleAdReplacement,#articleSideAd,#article_ad,#article_box_ad,#atlasAdDivGame,#banner-ad,#banner-ad-container,#banner-ads,#banner468x60,#banner728x90,#bannerAd,#bannerAdTop,#bannerAd_ctr,#banner_ad,#banner_topad,#bannerad,#bannerad2,#bbccom_mpu,#bbo_ad1,#bg_YieldManager-300x250,#bigAd,#bigBoxAd,#bigadbox,#bigadspot,#billboard_ad,#block-ad_cube-1,#block-thewrap_ads_250x300-0,#block_advert,#blox-big-ad,#blox-halfpage-ad,#blox-tile-ad,#botad,#bottom-ad-container,#bottom-ads,#bottomAd,#bottomAdSenseDiv,#bottomAds,#bottomRightAdSpace,#bottom_ad,#bottom_ad_area,#bottom_ads,#bottom_banner_ad,#bottom_overture,#bottom_sponsor_ads,#bottom_sponsored_links,#bottom_text_ad,#bottomad,#bottomadsense,#box-googleadsense-1,#box-googleadsense-r,#box1ad,#boxAd300,#boxAdContainer,#box_mod_googleadsense,#boxad1,#boxad2,#boxad3,#boxad4,#boxad5,#bps-header-ad-container,#btr_horiz_ad,#burn_header_ad,#button-ads-horizontal,#button-ads-vertical,#button_ad_container,#button_ad_wrap,#cellAd,#channel_ad,#channel_ads,#ciHomeRHSAdslot,#circ_ad,#cnnRR336ad,#cnnTopAd,#colRightAd,#column4-google-ads,#commercial_ads,#common_right_lower_player_adspace,#common_right_player_adspace,#common_top_adspace,#containerLocalAds,#containerMrecAd,#content-ad-header,#contentAd,#content_ad_square,#content_ad_top,#content_ads_content,#content_box_300body_sponsoredoffers,#content_box_adright300_google,#contentad,#contentad_imtext,#contentad_right,#contentads,#contentinlineAd,#contextual-ads-block,#contextualad,#coverads,#ctl00_MasterHolder_IBanner_adHolder,#ctl00_VBanner_adHolder,#ctl00_adFooter,#ctl00_cphMain_hlAd1,#ctl00_cphMain_hlAd2,#ctl00_cphMain_hlAd3,#ctl00_ctl00_MainPlaceHolder_itvAdSkyscraper,#ctl00_ctl00_ctl00_Main_Main_PlaceHolderGoogleTopBanner_MPTopBannerAd,#ctl00_ctl00_ctl00_Main_Main_SideBar_MPSideAd,#ctl00_ctl00_ctl00_tableAdsTop,#ctl00_m_skinTracker_m_adLBL,#ctl00_phCrackerMain_ucAffiliateAdvertDisplayMiddle_pnlAffiliateAdvert,#ctl00_phCrackerMain_ucAffiliateAdvertDisplayRight_pnlAffiliateAdvert,#ctrlsponsored,#cubeAd,#cube_ads,#cube_ads_inner,#cubead,#cubead-2,#defer-adright,#detail_page_vid_topads,#divAd,#divAdBox,#divWrapper_Ad,#div_video_ads,#dlads,#dni-header-ad,#download_ads,#ds-mpu,#editorsmpu,#evotopTen_advert,#exads,#featuread,#featuredAdContainer2,#featuredAds,#feed_links_ad_container,#first_ad_unit,#fl_hdrAd,#footer-ad,#footer-sponsored,#footerAd,#footerAdDiv,#footerAds,#footerAdverts,#footer_ad,#footer_ad_block,#footer_ads,#footer_adspace,#footer_text_ad,#footerad,#fr_ad_center,#frnContentAd,#from_our_sponsors,#front_advert,#front_mpu,#ft-ad,#ft-ad-1,#ft-ad-container,#fusionad,#fw-advertisement,#g_ad,#g_adsense,#ga_300x250,#gad,#gallery-ad-m0,#gallery_ads,#game-info-ad,#global_header_ad_area,#gmi-ResourcePageAd,#gmi-ResourcePageLowerAd,#google-ad,#google-ad-art,#google-ad-tower,#google-ads,#google-ads-bottom,#google-ads-left-side,#google-adsense-mpusize,#googleAd,#googleAds,#googleAdsense,#googleAdsenseBanner,#googleAdsenseBannerBlog,#googleAdwordsModule,#googleAfcContainer,#googleShoppingAdsRight,#googleShoppingAdsTop,#google_ad,#google_ad_test,#google_ads,#google_ads_frame1,#google_ads_test,#googlead,#googleads,#googlesponsor,#grid_ad,#gsyadrectangleload,#gsyadrightload,#gsyadtop,#gsyadtopload,#gtopadvts,#halfPageAd,#halfe-page-ad-box,#hdtv_ad_ss,#head-ad,#head_advert,#header-ad,#header-ads,#header-advert,#headerAd,#headerAdBackground,#headerAdContainer,#headerAdsWrapper,#headerTopAd,#header_ad,#header_adcode,#header_ads,#header_advertisement_top,#header_leaderboard_ad_container,#headerad,#headeradbox,#headline_ad,#hiddenadAC,#homeTopRightAd,#home_ad,#home_contentad,#home_spensoredlinks,#homepage-ad,#homepage_right_ad,#homepage_right_ad_container,#hometop_234x60ad,#hor_ad,#horizontal-banner-ad,#horizontal_ad,#houseAd,#hp-store-ad,#hpV2_300x250Ad,#hpV2_googAds,#icePage_SearchLinks_AdRightDiv,#icePage_SearchLinks_DownloadToolbarAdRightDiv,#inlinead,#inlinegoogleads,#inner-advert-row,#insider_ad_wrapper,#instoryad,#int-ad,#interstitial_ad_wrapper,#islandAd,#j_ad,#jmp-ad-buttons,#joead,#joead2,#ka_adRightSkyscraperWide,#landing-adserver,#lateAd,#lb-sponsor-left,#lb-sponsor-right,#leader-board-ad,#leader-sponsor,#leaderAdContainer,#leaderad,#leaderad_section,#leaderboard-ad,#leaderboard-bottom-ad,#leaderboard_ad,#left-ad-skin,#leftAdContainer,#leftAd_rdr,#leftAdvert,#leftSectionAd300-100,#left_ad,#left_adspace,#leftad,#leftads,#lg-banner-ad,#linkAds,#live-ad,#longAdSpace,#lowerthirdad,#mBannerAd,#main-ad,#main-ad160x600,#main-ad160x600-img,#main-ad728x90,#mainAd,#mainAdUnit,#mainAdvert,#main_ad,#main_rec_ad,#mastAdvert,#mastad,#masthead_ad,#masthead_topad,#medRecAd,#media_ad,#menuAds,#mi_story_assets_ad,#mid-ad300x250,#mid-table-ad,#mid_ad_title,#mid_mpu,#middlead,#middleads,#midrect_ad,#midstrip_ad,#mini-ad,#module-google_ads,#module_ad,#module_box_ad,#most_popular_ad,#mpu,#mpu-advert,#mpuAd,#mpuDiv,#mpuWrapper,#mpuWrapperAd,#mpu_banner,#mpu_holder,#mpu_text_ad,#mpuad,#mrecAdContainer,#ms_ad,#multiLinkAdContainer,#n_sponsor_ads,#namecom_ad_hosting_main,#narrow_ad_unit,#natadad300x250,#national_microlink_ads,#navi_banner_ad_780,#nba300Ad,#nbaMidAds,#nbaVid300Ad,#new_topad,#ng_rtcol_ad,#noresultsads,#northad,#oanda_ads,#onespot-ads,#p-googleadsense,#page-header-ad,#page_content_top_ad,#pcworldAdBottom,#pcworldAdTop,#pinball_ad,#player_ad,#player_ads,#portlet-advertisement-left,#portlet-advertisement-right,#post5_adbox,#priceGrabberAd,#print_ads,#printads,#product-adsense,#promo-ad,#promoAds,#ps-vertical-ads,#pub468x60,#publicidad,#r1SoftAd,#rail_ad1,#rail_ad2,#realEstateAds,#rect_ad,#rectangle-ad,#rectangle_ad,#refine-300-ad,#region-top-ad,#rh-ad-container,#rh_tower_ad,#rhsadvert,#right-ad,#right-ad-skin,#right-box-ad,#rightAd,#rightAd300x250,#rightAdColumn,#rightAd_rdr,#rightColAd,#rightColumnMpuAd,#rightColumnSkyAd,#right_ad_wrapper,#right_ads,#right_advertisement,#right_advertising,#rightad,#rightadvertbar-doubleclickads,#rightbar-ad,#rightside_ad,#rotatingads,#row2AdContainer,#rtMod_ad,#sAdsBox,#sb-ad-sq,#search-google-ads,#search_ads,#secondBoxAdContainer,#section-container-ddc_ads,#section_advertorial_feature,#servfail-ads,#sew-ad1,#shoppingads,#show-ad,#side-ad,#side-ad-container,#sideAd,#sideBarAd,#side_ad_wrapper,#side_ads_by_google,#sidead,#sidebar-125x125-ads,#sidebar-125x125-ads-below-index,#sidebar-ad-boxes,#sidebar-ad-space,#sidebar-ad-wrap,#sidebar-ads,#sidebar2ads,#sidebar_ad_widget,#sidebar_ads,#sidebar_sponsoredresult_body,#sidebarad,#sideline-ad,#single-mpu,#site-leaderboard-ads,#site_top_ad,#sky-ad,#skyAd,#skyScrapperAd,#sky_ad,#skyscraper-ad,#skyscraperAd,#skyscraper_ad,#skyscraper_advert,#sliderAdHolder,#slideshow_ad_300x250,#sm-banner-ad,#small_ad,#smallerAd,#speeds_ads,#speeds_ads_fstitem,#sphereAd,#splinks,#sponLinkDiv_1,#sponlink,#spons_left,#sponseredlinks,#sponsor-search,#sponsorAd1,#sponsorAd2,#sponsorAdDiv,#sponsorLinks,#sponsor_banderole,#sponsor_box,#sponsor_deals,#sponsor_panSponsor,#sponsored,#sponsored-ads,#sponsored-features,#sponsored-links,#sponsored-resources,#sponsored1,#sponsoredBox1,#sponsoredBox2,#sponsoredLinks,#sponsoredList,#sponsoredResults,#sponsoredSiteMainline,#sponsoredSiteSidebar,#sponsored_ads_v4,#sponsored_content,#sponsored_game_row_listing,#sponsored_links,#sponsoredlinks,#sponsoredlinks_cntr,#sponsoredresults_top,#sponsorlink,#spotlightAds,#spotlightad,#squareAd,#squareAdSpace,#square_ad,#start_middle_container_advertisment,#sticky-ad,#stickyBottomAd,#story-ad-a,#story-ad-b,#story-sponsoredlinks,#storyAd,#storyAdWrap,#subpage-ad-right,#subpage-ad-top,#swads,#synch-ad,#tabAdvertising,#tblAd,#tbl_googlead,#template_ad_leaderboard,#tertiary_advertising,#text-ad,#textAd,#textAds,#text_ad,#text_advert,#the-last-ad-standing,#thefooterad,#themis-ads,#tile-ad,#tmglBannerAd,#top-ad,#top-ad-container,#top-ad-menu,#top-ads,#top-ads-tabs,#top-advertisement,#top-banner-ad,#top-search-ad-wrapper,#topAd,#topAd728x90,#topAdBanner,#topAdContainer,#topAdSenseDiv,#topAds,#topAdvert,#topBannerAd,#topNavLeaderboardAdHolder,#top_ad,#top_ad_area,#top_ad_game,#top_ad_wrapper,#top_ads,#top_advertise,#top_advertising,#top_wide_ad,#topad,#topad_left,#topad_right,#topadblock,#topads,#topadzone,#topcustomad,#toprightAdvert,#toptextad,#towerad,#twogamesAd,#txt_link_ads,#undergameAd,#upperMpu,#upperad,#urban_contentad_article,#v_ad,#vert_ad,#vertical_ad,#vertical_ads,#video_cnv_ad,#video_overlay_ad,#walltopad,#welcomeAdsContainer,#welcome_ad_mrec,#welcome_advertisement,#wgtAd,#whatsnews_top_ad,#whitepaper-ad,#whoisRightAdContainer,#wide_ad_unit_top,#widget_advertisement,#wrapAdRight,#wrapAdTop,#y708-ad-expedia,#y708-ad-lrec,#y708-ad-partners,#y708-ad-ysm,#y708-advertorial-marketplace,#yahoo-ads,#yahoo-sponsors,#yahoo_ads,#yahoo_ads_2010,#yahooad-tbl,#yan-sponsored,#ybf-ads,#yfi_fp_ad_mort,#yfi_fp_ad_nns,#yfi_pf_ad_mort,#ygrp-sponsored-links,#ymap_adbanner,#yn-gmy-ad-lrec,#yreSponsoredLinks,#ysm_ad_iframe,#zoneAdserverMrec,#zoneAdserverSuper,.ADBAR,.Ad120x600,.Ad160x600,.Ad247x90,.Ad300x250,.Ad300x250L,.Ad728x90,.AdBox,.AdBox7,.AdContainerBox308,.AdHere,.AdInfo,.AdPlaceHolder,.AdRingtone,.AdSense,.AdSpace,.AdTitle,.AdUnit,.AdUnit300,.Ad_C,.Ad_D_Wrapper,.Ad_E_Wrapper,.Ad_Right,.Ads,.AdsBoxSection,.AdsLinks1,.AdsLinks2,.AdvertMidPage,.AdvertiseWithUs,.AdvertisementTextTag,.ArticleInlineAd,.BannerAd,.BlockAd,.BottomAffiliate,.CG_adkit_leaderboard,.CommentAd,.DeptAd,.FT_Ad,.FlatAds,.HPNewAdsBannerDiv,.HomeContentAd,.LeftTowerAd,.M2Advertisement,.MD_adZone,.MPU,.MPUHolder,.MiddleAdContainer,.PU_DoubleClickAdsContent,.Post5ad,.RBboxAd,.RelatedAds,.RightRailTop300x250Ad,.RightSponsoredAdTitle,.RightTowerAd,.SidebarAd,.SponsoredAdTitle,.SponsoredLinks,.SponsoredLinksGrayBox,.StandardAdLeft,.StandardAdRight,.TextAd,.TheEagleGoogleAdSense300x250,.TopAd,.TopAdL,.TopAdR,.UIStandardFrame_SidebarAds,.UIWashFrame_SidebarAds,.UnderAd,.VerticalAd,.WidgetAdvertiser,.ad-160x600,.ad-250,.ad-300,.ad-300-block,.ad-300-blog,.ad-300x100,.ad-300x250,.ad-600,.ad-728,.ad-background,.ad-banner,.ad-bigsize,.ad-block,.ad-blog2biz,.ad-bottom,.ad-box,.ad-button,.ad-cell,.ad-container,.ad-div,.ad-feedback,.ad-filler,.ad-footer,.ad-footer-leaderboard,.ad-google,.ad-gray,.ad-hdr,.ad-head,.ad-holder,.ad-homeleaderboard,.ad-img,.ad-island,.ad-leaderboard,.ad-links,.ad-medium,.ad-medium-two,.ad-mpu,.ad-other,.ad-placeholder,.ad-postText,.ad-poster,.ad-rect,.ad-rectangle,.ad-rectangle-text,.ad-related,.ad-rh,.ad-ri,.ad-right,.ad-right-txt,.ad-section,.ad-sidebar300,.ad-slot,.ad-slot-234-60,.ad-slot-300-250,.ad-slot-728-90,.ad-space,.ad-space-mpu-box,.ad-spot,.ad-statement,.ad-text,.ad-tile,.ad-top,.ad-top-left,.ad-unit,.ad-vtu,.ad-wrap,.ad-wrapper,.ad0,.ad1,.ad10,.ad120,.ad160,.ad160x600,.ad18,.ad19,.ad2,.ad21,.ad250c,.ad3,.ad300,.ad300_250,.ad300x250,.ad300x250Top,.ad300x250_container,.ad300x250box,.ad300x600,.ad310,.ad336x280,.ad343x290,.ad450,.ad468,.ad468_60,.ad6,.ad620x70,.ad626X35,.ad7,.ad728,.ad728_90,.ad728x90,.ad728x90_container,.ad8,.adAgate,.adBanner,.adBannerTyp1,.adBannerTypSortableList,.adBannerTypW300,.adBgBottom,.adBgMId,.adBgTop,.adBox,.adBoxContent,.adBoxSidebar,.adBoxSingle,.adCMRight,.adColumn,.adContainer,.adContour,.adCreative,.adDiv,.adElement,.adFrame,.adFtr,.adFullWidthMiddle,.adGoogle,.adHeader,.adHeadline,.adHolder,.adHome300x250,.adInNews,.adLabel,.adLeader,.adLeaderForum,.adLeaderboard,.adLeft,.adMastheadLeft,.adMastheadRight,.adMkt2Colw,.adModule,.adNewsChannel,.adNoOutline,.adNoticeOut,.adObj,.adPageBorderL,.adPageBorderR,.adPanel,.adRect,.adRight,.adSelfServiceAdvertiseLink,.adServer,.adSlot,.adSpBelow,.adSpace,.adSpacer,.adSpot,.adSpot-searchAd,.adSpot-textBox,.adSpotIsland,.adSquare,.adSummary,.adSuperboard,.adTag,.adText,.adTileWrap,.adTiler,.adTitle,.adTout,.adTxt,.adWithTab,.adWrap,.adWrapper,.ad_1,.ad_125,.ad_130x90,.ad_160,.ad_160x600,.ad_2,.ad_3,.ad_300,.ad_300_250,.ad_300x250,.ad_336,.ad_336x280,.ad_350x250,.ad_468,.ad_600,.ad_728,.ad_728x90,.ad_amazon,.ad_biz,.ad_block_338,.ad_bottom_leaderboard,.ad_box,.ad_box2,.ad_callout,.ad_caption,.ad_contain,.ad_container,.ad_content,.ad_content_wide,.ad_contents,.ad_descriptor,.ad_footer,.ad_framed,.ad_front_promo,.ad_header,.ad_hpm,.ad_info_block,.ad_label,.ad_launchpad,.ad_leader,.ad_leaderboard,.ad_left,.ad_linkunit,.ad_loc,.ad_lrec,.ad_medrect,.ad_mpu,.ad_mr,.ad_mrec,.ad_mrec_title_article,.ad_notice,.ad_p360,.ad_partner,.ad_partners,.ad_plus,.ad_post,.ad_power,.ad_rectangle,.ad_right,.ad_sidebar,.ad_skyscraper,.ad_slug_table,.ad_space,.ad_space_300_250,.ad_sponsor,.ad_sponsoredsection,.ad_spot_b,.ad_spot_c,.ad_square_r,.ad_square_top,.ad_text,.ad_title,.ad_top,.ad_top_leaderboard,.ad_tower,.ad_unit,.ad_unit_rail,.ad_warning,.ad_wide,.ad_wrap,.ad_wrapper,.ad_wrapper_fixed,.ad_zone,.adarea,.adbanner,.adbannerright,.adbar,.adborder,.adbot,.adbottom,.adbox,.adbox-outer,.adbox_366x280,.adbox_468X60,.adbox_bottom,.adboxclass,.adcode,.adcolumn_wrapper,.adcontainer,.adcopy,.addiv,.adfoot,.adfootbox,.adframe,.adhead,.adheader,.adheader100,.adhere,.adhoriz,.adi,.adinfo,.adinside,.adjlink,.adkit,.adkit-advert,.adkit-lb-footer,.adlabel-horz,.adlabel-vert,.adline,.adlink,.adlist,.adlnklst,.admarker,.admedrec,.admodule,.admpu,.adnotice,.adops,.adpadding,.adpic,.adright,.adrow,.adrow-post,.adrule,.ads-banner,.ads-categories-bsa,.ads-favicon,.ads-links-general,.ads-mpu,.ads-profile,.ads-right,.ads-sidebar,.ads-sky,.ads-text,.ads2,.ads3,.ads:not(body),.adsArea,.adsBelowHeadingNormal,.adsBox,.adsImages,.adsTextHouse,.adsTower2,.adsTowerWrap,.adsWithUs,.ads_300,.ads_728x90,.ads_big,.ads_big-half,.ads_catDiv,.ads_container,.ads_disc_anchor,.ads_disc_leader,.ads_disc_lwr_square,.ads_disc_skyscraper,.ads_disc_square,.ads_div,.ads_header,.ads_mpu,.ads_right,.ads_sc_tl_i,.ads_side,.ads_takeover,.ads_tr,.adsborder,.adsbyyahoo,.adscreen,.adsection_a2,.adsection_c2,.adsense,.adsense-heading,.adsense-right,.adsense-title,.adsenseBlock,.adsenseContainer,.adsenseblock,.adsenselr,.adsensesq,.adsidebox,.adsingle,.adslogan,.adspace,.adspace-MR,.adspace_buysell,.adspace_rotate,.adspacer,.adspot,.adstrip,.adtag,.adtext,.adtext_gray,.adtext_onwhite,.adtop,.adtravel,.adv-mpu,.adverTag,.adver_cont_below,.advert,.advert-box,.advert-head,.advert-horizontal,.advert-mpu,.advert-skyscraper,.advert-text,.advertCont,.advertContainer,.advertHeadline,.advertRight,.advertText,.advert_468x60,.advert_box,.advert_cont,.advert_leaderboard,.advert_note,.advertise,.advertise-here,.advertise-homestrip,.advertise-horz,.advertise-leaderboard,.advertise-vert,.advertiseContainer,.advertiseText,.advertisement,.advertisement-728x90,.advertisement-block,.advertisement-top,.advertisement468,.advertisementColumnGroup,.advertisementContainer,.advertisementLabel,.advertisementPanel,.advertisement_caption,.advertisement_g,.advertisement_header,.advertisement_horizontal,.advertiser,.advertising,.advertising-header,.advertising2,.advertisingTable,.advertising_block,.advertisment,.advertisment_two,.advertize,.advertorial,.advertorial-promo-box,.adverts,.advt,.advt-banner-3,.advt300,.advt720,.adwrapper,.adwrapper-lrec,.adwrapper948,.affiliate,.affiliate-link,.affiliate-sidebar,.affiliateAdvertText,.agi-adsaleslinks,.alt_ad,.anchorAd,.aolSponsoredLinks,.aopsadvert,.article-ads,.articleAd,.articleAds,.articleAdsL,.articleEmbeddedAdBox,.article_ad,.article_adbox,.article_mpu_box,.articleads,.aseadn,.aux-ad-widget-2,.b-astro-sponsored-links_horizontal,.b-astro-sponsored-links_vertical,.banner-ad,.banner-ads,.banner-adverts,.banner300x100,.banner300x250,.banner468,.bannerAd,.bannerAdWrapper300x250,.bannerAdWrapper730x86,.banner_300x250,.banner_728x90,.banner_ad,.banner_ad_footer,.banner_ad_leaderboard,.bannerad,.barkerAd,.base-ad-mpu,.bgnavad,.big-ads,.bigAd,.big_ads,.bigad,.billboard_ad,.block-ad,.block-adsense,.block_ad,.blocked-ads,.blog-ads-container,.blogAdvertisement,.blogBigAd,.blog_ad,.body_ad,.body_sponsoredresults_bottom,.body_sponsoredresults_middle,.body_sponsoredresults_top,.bookseller-header-advt,.bottomAd,.bottomAds,.bottom_ad_block,.bottom_sponsor,.bottomad,.bottomrightrailAd,.bottomvidad,.box-ads,.boxAd,.box_ad,.box_advertisment_62_border,.box_content_ad,.box_content_ads,.boxad,.bps-ad-wrapper,.bps-advertisement,.bps-advertisement-inline-ads,.bullet-sponsored-links,.bullet-sponsored-links-gray,.burstContentAdIndex,.buttonAd,.buttonAds,.buttonadbox,.bx_ad,.bx_ad_right,.cA-adStrap,.cColumn-TextAdsBox,.care2_adspace,.cb_footer_sponsor,.cb_navigation_ad,.cbstv_ad_label,.cbzadvert,.cdAdTitle,.cdmainlineSearchAdParent,.cdsidebarSearchAdParent,.centerAd,.center_ad,.centerad,.clearerad,.cm_ads,.cms-Advert,.cnn160AdFooter,.cnnAd,.cnnMosaic160Container,.cnnStoreAd,.cnnStoryElementBoxAd,.cnnWCAdBox,.cnnWireAdLtgBox,.cnn_728adbin,.cnn_adcntr300x100,.cnn_adspc336cntr,.cnn_adtitle,.column2-ad,.conductor_ad,.confirm_ad_left,.confirm_ad_right,.confirm_leader_ad,.consoleAd,.container_serendipity_plugin_google_adsense,.contentAd,.content_ad,.content_adsq,.contentad,.contenttextad,.cp_ad,.cpmstarHeadline,.cpmstarText,.cs-mpu,.cspAd,.ct_ad,.cubeAd,.cube_ads,.darla_ad,.dartAdImage,.dart_ad,.dart_tag,.dartadvert,.dartiframe,.dc-ad,.dcAdvertHeader,.deckAd,.deckads,.detail-ads,.detailMpu,.divads,.divider_ad,.dmco_advert_iabrighttitle,.download_ad,.downloadad,.dynamic_ad,.ec-ads,.entryad,.ez-clientAd,.f_Ads,.featuredAds,.featuredadvertising,.flagads,.flash_advert,.flashad,.flexiad,.flipbook_v2_sponsor_ad,.footerAd,.footerAdModule,.footerTextAd,.footer_ad,.footer_ads,.footer_block_ad,.footer_line_ad,.footerad,.ft-ad,.ftdContentAd,.full_ad_box,.g3rtn-ad-site,.g_ggl_ad,.ga-textads-bottom,.ga-textads-top,.gads_cb,.gglAds,.googads,.google-ad-container,.google-ads,.google-ads-boxout,.google-right-ad,.google-sponsored-ads,.google468_60,.googleAd,.googleAd-content,.googleAd-list,.googleAdBox,.googleAdSense,.googleAd_body,.googleAds,.googleAds_article_page_above_comments,.googleAdsense,.googleProfileAd,.google_ads_bom_title,.googlead,.googleaddiv,.googleaddiv2,.googleads,.googleads_300x250,.googleads_title,.gpAds,.gradientAd,.gsfAd,.gt_ad_300x250,.gt_ad_728x90,.gutter-ad-left,.gutter-ad-right,.h_Ads,.h_ad,.hd_advert,.header-ad,.header-advert,.headerAd,.headerAds,.headerAdvert,.header_ad,.header_ad_center,.header_advertisment,.hi5-ad,.highlightsAd,.hm_advertisment,.home-ad-links,.homeAd,.homeMediumAdGroup,.home_ad_bottom,.homepage-ad,.homepageFlexAdOuter,.homepageMPU,.hor_ad,.horizontalAd,.horizontal_ad,.hortad,.houseAdsStyle,.hp2-adtag,.hp_ad_cont,.hp_ad_text,.hp_t_ad,.hp_w_ad,.ic-ads,.ico-adv,.idMultiAd,.image-advertisement,.imageads,.in-page-ad,.in-story-text-ad,.indy_googleads,.inline-mpu-left,.inlineSideAd,.inline_ad_title,.inlinead,.inlist-ad,.inner-advt-banner-3,.innerAds,.innerad,.inpostad,.islandAd,.islandAdvert,.islandad,.jp-advertisment-promotional,.js-advert,.kw_advert,.kw_advert_pair,.l_ad_sub,.l_banner.ads_show_if,.largeRectangleAd,.leader_ad,.leaderboardAd,.left-ad,.leftAd,.left_ads,.leftad,.leftbar_ad_160_600,.leftnavad,.lgRecAd,.lg_ad,.linead,.link_advertise,.live-search-list-ad-container,.log_ads,.lowerAds,.m_banner_ads,.macAd,.macad,.main-tabs-ad-block,.main_ad,.main_adbox,.map_media_banner_ad,.marginadsthin,.marketing-ad,.mdl-ad,.media-advert,.medium-rectangle-ad,.messageBoardAd,.micro_ad,.mid_ad,.midad,.min_navi_ad,.miniad,.mobile-sponsoring,.mod-ad-lrec,.mod-ad-n,.mod-adopenx,.mod_admodule,.module-ad-small,.module-ads,.moduleAdvertContent,.modulegad,.moduletable-advert,.moduletablesquaread,.mpu,.mpu-ad,.mpu-footer,.mpu-fp,.mpu-title,.mpu-top-left,.mpu-top-right,.mpuAd,.mpuBox,.mpuContainer,.mpuTextAd,.mpu_ad,.mpu_gold,.mpu_holder,.mpu_platinum,.mpu_text_ad,.mpuholderportalpage,.mrec_advert,.ms-ads-link,.msfg-shopping-mpu,.mwaads,.nSponsoredLcContent,.nSponsoredLcTopic,.nadvt300,.narrow_ad_unit,.narrow_ads,.naviad,.nba300Ad,.nbaT3Ad160,.nbaTVPodAd,.nbaTwo130Ads,.nbc_ad_carousel_wrp,.newTopAdContainer,.newad,.nf-adbox,.nn-mpu,.noAdForLead,.normalAds,.nrAds,.oas-bottom-ads,.oio-banner-zone,.oio-link-sidebar,.oio-zone-position,.onethirdadholder,.openx,.openx-ad,.other_adv2,.ov_spns,.pageGoogleAd,.pageGoogleAdFlat,.pageLeaderAd,.pagead,.partnersTextLinks,.pencil_ad,.player_ad_box,.player_page_ad_box,.pnp_ad,.podSponsoredLink,.post-ad,.post_ad,.post_sponsor_unit,.postbit_adbit_register,.postbit_adcode,.prebodyads,.premium_ad_container,.promoAd,.promoAds,.promo_ad,.publication-ad,.publicidad,.puff-advertorials,.qa_ad_left,.quigo-ad,.qzvAdDiv,.r_ad_box,.rad_container,.rectad,.rectangleAd,.rectanglead,.redads_cont,.regularad,.relatedAds,.remads,.result_ad,.results_sponsor,.results_sponsor_right,.rght300x250,.rhads,.rhs-ad,.rhs-ads-panel,.right-ad,.right-ad-holder,.right-ad2,.right-ads2,.rightAd,.right_ad,.right_ad_text,.right_ads,.right_hand_advert_column,.rightad,.rightad_1,.rightad_2,.rightads,.rightadunit,.rightcol_boxad,.rightcoladvert,.rt_ad1_300x90,.rt_ad_300x250,.rt_ad_call,.savvyad_unit,.sb-ad-sq-bg,.sbAdUnitContainer,.sb_adsN,.sb_adsNv2,.sb_adsW,.sb_adsWv2,.scanAd,.sci-ad-main,.sci-ad-sub,.search-results-ad,.search-sponsor,.search-sponsored,.searchAd,.searchSponsoredResultsBox,.search_column_results_sponsored,.search_results_sponsored_top,.section-sponsor,.section_mpu_wrapper,.selfServeAds,.sidbaread,.side-ad,.side-ads,.side_ad,.side_ad2,.sidead,.sideadsbox,.sideadvert,.sidebar-ad,.sidebar-text-ad,.sidebarAd,.sidebarAdUnit,.sidebarAdvert,.sidebar_ad,.sidebar_ad_300_250,.sidebar_box_ad,.sidebarad,.sidebarad_bottom,.sideheadnarrowad,.sideheadsponsorsad,.singleAd,.singleAdsContainer,.singlead,.sitesponsor,.skinAd,.skin_ad_638,.sky-ad,.skyAd,.skyAdd,.sky_ad,.skyscraper-ad,.slpBigSlimAdUnit,.slpSquareAdUnit,.sm_ad,.smallSkyAd1,.smallSkyAd2,.small_ad,.small_ads,.smallad-left,.smallsponsorad,.specialAd175x90,.spl_ad,.spl_ad2,.spl_ad_plus,.splitAd,.spons-link,.sponslink,.sponsor-ad,.sponsor-links,.sponsorArea,.sponsorPost,.sponsorPostWrap,.sponsor_line,.sponsoradtitle,.sponsorbox,.sponsored,.sponsored-chunk,.sponsored-editorial,.sponsored-links,.sponsored-post,.sponsored-results,.sponsored-text,.sponsoredLinks,.sponsoredLinksHeader,.sponsored_ads,.sponsored_box,.sponsored_box_search,.sponsored_by,.sponsored_links,.sponsored_links_title_container,.sponsored_links_title_container_top,.sponsored_links_top,.sponsored_results,.sponsoredibbox,.sponsoredlinks,.sponsorlink,.spotlightAd,.squareAd,.square_ad,.squared_ad,.ss-ad-mpu,.staticAd,.store-ads,.story_AD,.subad,.subcontent-ad,.supercommentad_left,.supercommentad_right,.supportAdItem,.surveyad,.t10ad,.tab_ad,.tab_ad_area,.tablebordersponsor,.tadsanzeige,.tadsbanner,.tadselement,.tallad,.tblTopAds,.tbl_ad,.teaser-sponsor,.teaserAdContainer,.teaser_adtiles,.text-ad-links,.text-g-advertisement,.text-g-group-short-rec-ad,.text-g-net-grp-google-ads-article-page,.textAd,.textAds,.text_ad,.text_ads,.textad,.textad_headline,.textadbox,.textads,.textlink-ads,.thisIsAd,.thisIsAnAd,.ticket-ad,.tileAds,.title-ad,.title_adbig,.tncms-region-ads,.toolad,.toolbar-ad,.top-ad,.top-ad-space,.top-ads,.top-menu-ads,.topAdWrap,.topAds,.topAdvertisement,.topBannerAd,.top_ad,.top_ad_728_90,.top_ad_disclaimer,.top_ad_wrapper,.top_ads,.top_advert,.top_advertising_lb,.top_container_ad,.top_sponsor,.topad,.topadbox,.topadspot,.topcontentadvertisement,.topic_inad,.topstoriesad,.towerAd,.towerAdLeft,.towerAds,.tower_ad_disclaimer,.ts-ad_unit_bigbox,.ts-banner_ad,.ttlAdsensel,.twoColumnAd,.twoadcoll,.twoadcolr,.tx_smartadserver_pi1,.txt-ads,.txtadvertise,.type_miniad,.type_promoads,.usenext,.vertad,.videoAd,.videoBoxAd,.video_ad,.view-promo-mpu-right,.wide-ad,.wide-skyscraper-ad,.wideAdTable,.wide_ad_unit_top,.wide_ads,.widget-entry-ads-160,.wikia_ad_placeholder,.withAds,.wnMultiAd,.wpn_ad_content,.x03-adunit,.x04-adunit,.y-ads,.y7-advertisement,.yahoo-sponsored,.yahoo_ads,.yan-sponsored,.ygrp-ad,.yrail_ad_wrap,.yrail_ads,.ysmsponsor,.ysponsor,a[href^="http://adserving.liveuniversenetwork.com/"],a[href^="http://latestdownloads.net/download.php?"],a[href^="http://secure.signup-page.com/"],a[href^="http://secure.signup-way.com/"],a[href^="http://www.FriendlyDuck.com/AF_"],a[href^="http://www.adbrite.com/mb/commerce/purchase_form.php?"],a[href^="http://www.google.com/aclk?"],a[href^="http://www.liutilities.com/aff"],a[href^="http://www.my-dirty-hobby.com/?sub="],a[href^="http://www.ringtonematcher.com/"],#mbEnd[cellspacing="0"][style="padding: 0pt; white-space: nowrap;"],div#mclip_container:first-child:last-child,div#tads.c,table.ra[align="left"][width="30%"],table.ra[align="right"][width="30%"] { visibility:hidden !important; display:none !important; }
laynwindows
you'll be fine, on mine, i made the center of the bag, hang a little bit over the edge of the bars. and then made a plate that went under the rest of the bag hangin over and gusseted it
nissandoordragger
^^^^^your bushing are gonna hate you for that
bigjon's avatar
bigjon
just drill all the way through the bar and use a longer bolt!
s10
last post by baha +1y
