Valves
g_unit1_0_1@hotmail.com's avatar
Valves
92mazdadropped's avatar
92mazdadropped
Hey i got some 1/2"smc valves , i was wondering if anyone has a diagram of how they set up their valves Im not 100% sure on what fittings to use and how to set it up but heres a rough ideaim gunna run FBSS ,i got 8 valves i want to run 4 dump controlsthis is how i want it to work:i got 2 Tanks each 3 Gallon,3 portsso thats 6 ports in totalTank 1 :1 port for the compressor1 airline running from the tank to the valves1 airline for the air gaugeTank 2:1 port for the compressor1 airline running to the valves1 airline for the air gaugeAlso i will have a line that splits off and runs to the pressure switch from the line to the air gaugesSo i got two airlines ,each one running to 4 valves [one set for the front one set for the back]oviously there has to be a airline going in one end of the valves ,2 dump control will be in the mix and another airline leaving the valves feeding the bags (that will split into two ,one per bag)but im not 100% sure how to set this up anyone got pictures or diagrams , ive seen the ones from SD but they dont really help
bigperm's avatar
bigperm
try this:
(dump)-tee#1-(fill)-tee#2-(fill)-tee#3-(dump)
run your line from your tank to tee#2, then run left front bag to tee#1, and right front bag to tee#3...
do the same for the rear, and that should do ya! hope that makes sense!
s10
last post by baha +1y
