2.2 liter turbo???
2.2 liter turbo???
1987bseiresman
i was curious if the 2.2. liter motor that's turbo'd does it rev high at idle??? also how much boost can you run??? also what's best horsepower with a 2.2. liter turbo'd???
LayFrame's avatar
LayFrame
The stage 1 kit was designed to be affordable and simple to install while providing the much needed performance boost to the 2.2L engines. This kit will bring a completely stock 2.2L S-10 from mid 18's to low 15's in the 1/4 mile. Zero to 60 times will improve from 11 seconds to 7 seconds. Horsepower at the wheels will increase from the stock 100hp up to around 200hp. Highway gas mileage improved from 26mpg to 31mpg at a cruising speed of 75mph*. City gas mileage without hitting boost is undecided... we just can't resist the urge to boost! Drivability remains unchanged. There are no idle, starting, or overheating problems. Stage 1 kits are set at 8psi. However, Stage 1 kits are capable of producing around 400hp to the wheels when combined with a built engine and the fuel and ignition components needed to support boost levels of 20psi. Stage 1 Kit Includes:T3/T4 TurboFragola Lubrication KitTurbo BracketBell IntercoolerIntercooler BracketsAluminum Intercooler PipingSilicone CouplingsT-bolt ClampsType RS Blow-off ValveStainless Steel Turbo CollectorStainless Steel Downpipe Rising Rate Fuel Pressure RegulatorMaradyne Electric Fan Conversion KitAutometer Boost GuageVaccum HarnessesCone Style Air FilterPCV FilterAs well as all necessary gaskets, hardware, instructions, and stickersThe complete Stage 1 Turbo Kit is $2300.00!!! Thats just stage 1..Stage 3 runs into the 500+ range, but limited info is available at the moment..All this was at www.dts2.net     Ive been watching this website for awhile now.
1987bseiresman
thanks man!!!!
