couldnt find....best way to lay out 96 ranger on 20s
jdozier1279
i did my search but could not find. what is the best but cheapest way to lay out a 96 ranger on 20s.....what do u do with the drop beams??any help greatly appreaciated. pics work great
IMLOWER's avatar
IMLOWER
yota clip it is the best route to go
kaoss's avatar
kaoss
^^^ Beat me to it! Do a search on Toyota or Yota front clip.
cheese's avatar
cheese
Edited: 6/12/2009 3:20:55 PM by cheese
Edited: 6/12/2009 3:20:05 PM by cheeseCHEAP & RANGER IN THE SAME SENTANCE LOLYOTA CLIP IT !!!
kdaddy's avatar
kdaddy
Edited: 6/12/2009 4:20:04 PM by kdaddy
All you have to do is change the radius crossmembers and the tranny members drop i-beams and relocate everything under the hood and it will lay 20's
kdaddy's avatar
kdaddy
societyoutkast's avatar
societyoutkast
mine layed on 20's with drop beams and suicide doors bag mounts...had a tranny member on it but i took it off and put stock back on to put my ac and stuff back in you..you can keep ac with aftermarket c member but i didnt want to try to section blower box and stuff
slammedxonair's avatar
slammedxonair
you should have DJM beams and you have to notch the engine crossmember and frame for the beams and tie rods. make sure you have tranny and radius arm relocators on before you setup your bag backets. so you can get the propper geometry. Tubular bag mounts are the best way to go. Or for better camber go with a mustang ii front clip or pre 95 yota front clip. Oh yea and check out www.rangerpowersports in the adjustable suspension section.
