mighty max frontend setup
dragitall
been thinkin about tradin my truck for a 89 mighty max and i was just wantin to get some ideas for what i could do, thanks!
jmurphy's avatar
jmurphy
Here is a link to some of my build pics from my old Max. Kinda gives you an idea.
dragitall
dont see it?? what kind of control arm/spindal setups are you guys doing? if i got it id want to do the toyota5 lug swap. and does the single cab have a 1 piece driveshaft of 2 piece??
slowram's avatar
slowram
on the front of mine i did cups, w/ a 3" drop spindle, pretty simple and clean (stock uppers and lowers, and still have a sway bar). single cab has a 1 piece driveshaft.
D350's avatar
D350
--------------------------------------------- Originally posted by slowram on the front of mine i did cups, w/ a 3" drop spindle, pretty simple and clean (stock uppers and lowers, and still have a sway bar). single cab has a 1 piece driveshaft. --------------------------------------------- Interested in knowing where you got 3" drop spindles.  To my knowledge AIM is the only company making drop spindles for this truck.  It's been a year though.   The spring cup needs to be cut down quite a bit to get any significant drop out of it.  Some use cups... I developed a removable back plate setup.  The 5 lug conversion is a breeze using Toyota parts.  Check out photos of all that in my build thread.  Granted, mine is an 86 (very different body style) but the frames and suspension didn't change.   http://www.streetsource.com/forum/topic.aspx?topic_id=105929&page=1    Hit me up if you've got questions.  Vizualcreep@yahoo.com
dragitall
whats the offset for a 22 to tuck with the toyota rearend?? and has anybody tried to use a 2pc drice shaft in a mitsu? like a single cab mazdas?? or a extended cab driveshaft shortend??  shoulda called this 21 questions lol
nvrdoned50's avatar
nvrdoned50
you can put a extra cab driveshaft which is 2 piece but good luck finding a extra cab...there rare..and of course youd have to get it shortend...look in my profile at all of my d50s...one is bodydropped and underconstruction....
