engine performance ?s
file13hotboy5@yahoo.com's avatar
minimazdaon20s's avatar
minimazdaon20s
so im sendin my motor off to get rebuilt next friday, what i was wonderin is what can i do to get the most horsepower out of the old dawg. i made a list of what i have heard u can do.
1.bore it over and if so how much with out blowin it up2.pacesetter header 3.delta cam and rockers arms4.port and polish5.webber carbs I think thats all i found on ssm i was wonderin is there more, a buddy of mine bought a mazda out of ky that was fast as hell and then sold it before i could take a look at it but the guy was off here his name was IBUILDCUSTOMS. where are u russ d i no u no alot help me out
bodydropped's avatar
bodydropped
mainly when you bore it your either cleaning it up the cylinder walls due to alot of mileage or deep scratchs in them but im not sure how big you can go thou i would leave that up to the machine shop thou
EKSESSIV CONTROL's avatar
EKSESSIV CONTROL
small block chevys work nice
minimazdaon20s
yea i would love to put a sbc in it but gas prices are way to high for that,plus the gov is paying for the rebuild thanks to the checks we got back, thanks bush haha
layin22ʹs's avatar
layin22ʹs
hey bro yeah everything you said in the first post will gain you.but it has to be a combo,if you just put a bigger carb on no,then you are just adding fuel.you have to burn the fuel and get rid of the exaust.if you boreit .30 over is good with a pistion that has more compresion,add a cam and roller rockers,and the weebers with a header then yeah you should have a pretty good power jump.mabey all of what you said and a good ignition set up like m.s.d and you whould prolly be pretty happy.but have the shop thats rebuilding it bore it out or let you know if its a virgin block,it may have been done before.and tey will tell you how far you can go with no problems.but just think of it like this,if you give it more fuel it needs more fire,more air,and more exaust,take one away and you will get less power add all in a good como and you will gain.sorry for the book im outa words.
minimazdaon20s
thats what i wanted to no,cause im sendin it off to get the block and the vavle done at the same time so i will have a fresh engine, i dont want nos and all that other stuff like turbos and superchargers, it would be nice to have but thats a little much.
I was lookin for russ d input on this , i figured he would be tearin this up by now
minimazdaon20s
somebody should make a sticky on this subject that would be sweet
Kyrasis6's avatar
Kyrasis6
Don't waste you're time on the cam, I would just spend the money on a light weight fidanza flywheel, you will be happier with it. One beauty about raising compression is that it helps gas mileage as long as you stay off the throttle.
Here is a place with some additional reading info for you:B2200 Tech Section
minimazdaon20s
thanks kyrasis6, but where is a good place to buy a weber carb and the pacersetter header and that flywheel u just told me about, i go onto mazdatruckin.com all the time time
