DRL's (Daytime Running Lights)
luv2xclr8_tn@yahoo.com's avatar
luv2xclr8's avatar
luv2xclr8
Is there a simple way to turn these off or is it really involved?
(Have not had truck but a couple of months)
duallme's avatar
duallme
easy all you have to do is pull a fuse not sure which one off top of my head
luv2xclr8's avatar
luv2xclr8
I thought maybe that was the case, maybe I can Google the fuse number?
Thanks
someotherguy's avatar
someotherguy
Or just check the sticker on the inside of your fuse cover, it's #15. Remember the rows are numbered with the # above the fuse, easy to forget when you can't see the first row's numbers without kneeling down.
Richard
krewzlo's avatar
krewzlo
On mine, if I just pulled the fuse, it also caused the headlights not to function correctly, as I remember I lost one side of lo or hi beams. It has been many years since I messed with it so I can't remember for sure.
layed521's avatar
layed521
Why would you wanna disable the DRLs?
luv2xclr8's avatar
luv2xclr8
Mainly at Cruise-In's where I want all the lights lit up but the Headlights.
lockone's avatar
lockone
What year is the truck?
Some trucks that have the dome light override button below the headlight switch, you can push the button 3 times and it will cut the DRL off.
krewzlo's avatar
krewzlo
just hit the ebrake a click or two and they should go out. Or put a switch on the ebrake wire to bypass it and send it to ground as I remember will shut them off too.
someotherguy
Your headlight switch is bad.
Richard
