Will the front hubs and brakes and rear axle from a chevy 3500 cube van work on my truck or do they have to come from a truck? My truck was converted to 1/2 ton parts back in 97 and now I want to make it a dually. Thanks
lockone
I am not positive but they should be the same.
h2omelon(nick)
That would be great if it is the same. There are no duallys in any of the local pull a parts but plety of cube vans.
lockone
The easiest way to find out is to go to your local parts store and see if some of the suspension parts will interchange or cross reference.
h2omelon(nick)
Did some checking and the control arms,brakes,spindles are all the same exact part numbers. The only question I have now is if the rear axle is the same.
okcderek
Rear axel might work out to your benefit if its shorter. Be easier to run 22s
