need opinions
need opinions
CS
cheeks Sunset SD
Ok I need opinions on what to do with the engine in my courier. There is no way in hell I am going to cut a hole in the hood for a b/d so as I see it now I got 2 good options. #1 I have a friend with a rotary and a transmission I can get for cheap, the rotary is a tiny ass motor and I could almost door it with a stock hood. #2 302 v-8 cool motor loud in a small truck should be able to get into the rocker an inch or so and keep the hood. I really dont care about power just want something clean and under the hood. Biggest concern about the 302 is cooling and with the rotary I hear they are problematic?sorry about the long post.
lucky_brew's avatar
lucky_brew
why dont you lower the motor mounts for hood clearance ?
CS
cheeks Sunset SD
the four banger that is in there now is tired and it is also tall as shyte, from the air cleaner to the hood now it is about 2" I would like to go an inch into the rocker which I need around 3 or so.
fatboysS1O's avatar
fatboysS1O
CS
cheeks Sunset SD
bump
thebagged1
i like going the different route... id go rotary or even turbo coupe motor be nice
TwistedMinis's avatar
TwistedMinis
I like Rotary motors. And I know they are capable of a lot of power.
The 302 would also be cool if you have enough room. You can run a thicker aluminum radiator and an electric fan and probably be fine as far as cooling goes.
standardbyker88's avatar
standardbyker88
rotary
disfiguredS10's avatar
disfiguredS10
I vote rotary.
fatboysS1O's avatar
fatboysS1O
dont know a whole lot about the rotary motors but ive seen one in a past nissan cover truck and i was told it was slower than frozen backed up pond water. dont know which motors are capable of what but i dont think the owner liked it too much besides the fact that it was different.
