honda passport, amigo, upgrade interior??
d2tropical22@yahoo.com's avatar
dguzzardo22's avatar
dguzzardo22
so after my search ive come to find out >>>
Will this work? Am i right ??
a 94-97 passport / amigo
The dash will bolt right in w/ minor modification to get it all working . the cluster will work and all with the a/c vents ?
The 1 piece doors will bolt right up and i can use the door panel and everything on it also and it'll all fit
the fenders are wide enough to tuck 20's w/o rubbing . they are bigger than the stock isuzu ?
all this is going on a 1990 isuzu pickup. single cab
please can someone tell me if im correct and has anyone done this before ?
Thanks,
dguzzardo22
Originally posted by sicpupidaho
you will need the brace that goes in the back that the steering wheel bolts to.You we need to take some of the brackets off that go up to the defrost vents(that black piece).you can use your gauge cluster if you trim some of it.the e brake needs removed or you can cut the lower panel.thats all i can think of right now i will add more when i remember.
Originally posted by isuzusponge
OK. The mounting bolts on the 95.5 -97 rodeo and the passports are the same as your truck, but nothing else is going to line up. The wiring of the dash is different, and the heater control and gauge cluster are different. To add to that, when you go to the new dash, your door panels will not match up with the ends of the dash. The mod is cool looking, and would work with a lot of modifications, but would be a bitch to get all the factory shit working like it came that way. Good luck.
Amigo or Passport that are 1993 or newer, you can swap out the door guts(Window, Window tracks, and Mech). The only problem will be in where the mirror mounts. You may have to do something creative with the very front. Or if you are going to repaint the Zu, just swap the entire door. Iknow where there used to be one that was being parted out in Sumner. Let me know what you need.
I will give you the list of years that will swap over to the 88-92 Pups:1) 93-95 Pup2) 93-97 Rodeo and Passports3) 94 Amigo only(for some reason all 93 amigos I ever seen had the wing still,...maybe to get rid of leftover wing windows.)
sponge splawn's avatar
sponge splawn
Everything you have written is correct except the fenders. Rodeo and Passport and Pup fenders from 1988-1997 are all the same. The only fender that is different is the 1989-94 Amigo fenders. They used to be necessary for 20s, but with the new offset on the Gm 6 lug vehicles, they really arent that needed any more. You can find a 20 with a great enough offset to tuck under normal fenders. If you look at my 22s on my Rodeo in the pic, you will notice how much room I have. I could go back to normal fenders. It just takes some searching.
Related Discussions in Isuzu
