GM oem wheel fitment
bhb
Will the later factory wheels pictured below, (2001? and up) fit the '88-'00 bodystyle?
lockone's avatar
lockone
Lug patterns are the same but the hub bore is bigger on the 01-up truck. You will need some hub rings to center the wheels to the truck properly.
bhb
Thanks for the info. Do you have such a hub ring, or know where to get them?
lockone's avatar
lockone
I make all the ones that I need. I have yet to find companies that make them because it is only about 5mm but it makes a world of a difference in vibration.
bhb
So..How much to make me a set? Just trying to weigh my options as to what wheels I want run?
scooter's avatar
scooter
hey, just cruzin thru old posts and came across this one. i am having a small problem centering my wheel adapters. the adapters are about 5 mm larger than the hubs. (96 3500 chevy). i wonder if the adapters i have are for 01 and up? do you sell the hub rings you were talking about in this post lockone? i would be interested in buying 4 of them and tryin it out. i tapered 4 of the lugs holes in the adapter to use the studs to center but i am not that happy with it. thanks in advance. chris
N
nicolepharris83
Moving is so hard especially for people who are not prepared.
It may result to damaged things especially when not handle well.
Your moving can be successful if you have the best moving company.
They can give you services that you need and they can help you in moving well.
lockone's avatar
lockone
PM sent.
