Ok im going to run 6 wheels9tires r 265/35/22.. my question is if i order these extra wide fenders would i clear.
whats factory width
these say 2inch or 100inch wide..
lockone
Really depends on the rear end width in your truck. Most 97-up trucks it takes upward of 3"+ to clear the 4 wheels in the rear. Some 99-2000 takes 4"+.
giovanni
what code on glove box tab am I looking for to find the rear end I have?? ?
lockone
The code doesn't really matter. What you need is to measure the rear axle. You can also measure front the mounting surface on your rear axle outward and add 13.75" to that plus about an 1" overhang for your tires and that will be how much your wheels will stick out past the fenders.
giovanni
Ok called dealer I have GT5 with 410s in my 98 gmc
jbweld46
i got a srw rearend if you dont want 2 play with your fenders
