INJECTOR FOR 93 454 MOTOR REPLACMENTS
BN
big no
ANYONE OUT THERE KNOWS WHICH INJECTORS TO PUT ON 454 BIG BLOCK 94 DUALLY IF U HAVE SPACER AND A K&M FILTER ON IT MY TRUCK FEELS LIKE IT COULD USE SOME MORE FUEL TO IT!
WL
wide load c-30
Adjustable fuel pressure regulator
BN
big no
ok thanks
bhb
You may want to upgrade your fuel pump as well. TBI pumps are only rated to 15 psi. TPI pumps are rated 30 psi. The fuel pressure regulator will contol it, and run excess back to the tank.
someotherguy's avatar
someotherguy
If you want to go that route, the 94-95 7.4 TBI pump is probably the same pump...they changed the injectors and pump on those years, spec is like 26-32 PSI.
Richard
